Re: At long last!
[Sorry if this is a double post, but my internet dropped out while I was trying to post the original!]
After a couple of false starts (and a couple of thousand pounds!), finally seem to have a sorted bike . Photo is at Burwick, as far south as you can get on Orkney, and then I rode to Birsay, as far north as you can get. All told, 100 miles today and 55.6mpg. I'm a happy bunny. Time to get my entry in for the Orkney Vintage Club summer show.
Kevin
20180514_113838-jpg
Makes my one look rather shabby. You will have to venture south to that other island of Great Britain to get some proper miles in!
:D I do have a bit of a plan formulating, but there might not be enough time for me to finalise it!
Previously Dan Field wrote:
Nice looking bike!
Thanks, Dan. It's running well too - (fingers crossed, pretend I didn't say that!) :D
Previously George Phillips wrote:
Which make of carrier is it, Kevin? And did it need fettling?
George
Hi George
It's a Craven Carrier. It was on when I bought the bike and I thought I would take it off as it is a bit 'old man' - then I realised I AM an old man and it's damn useful! :D
I haven't worked out how to attach more than one photo to a post, so I've made a PDF with photos in. It doesn't seem as if any great amount of fettling was required, other than spacers.
Kevin
craven-carrier-pdf
Nice machine, is this the most Northerly Norton in the British Isles?
As for 55.6 Mpg, I regularly used to get 55 mpg from my BMW K75,740cc which I suppose wasn't bad!
Are the roads all twists and turns?
Hi John.
Thank you. Strictly speaking, I know of one, under restoration, 650SS which is about half a mile further north than me! :D
I'm anticipating a slight improvement in the consumption as the engine beds in after relining the bores, new mains and new valves.
Without exaggerating, the roads here are a fabulous mix of long straights, some gentle and some tight bends. Traffic is a joke - i.e. none to speak of, and the lack of trees gives perfect sight lines across bends. Now, if only we had more sunny days! ;)
Kevin
Hi John.
Kevin
Hello now looking at your rear wheel looks to me like an 18 with a 4.00 tyre these were only fitted to export Norton 650 Manxman built from 7th of November1960 well I should know as I own one yours Anna J
056-2-jpg
Hi John.
Kevin
Hi Anna,
Wow, that's bright! :)
The rear tyre is a 4.10x19 as per the attached photo. It was first registered on 23 April 1965 (hence it is called George :D ) to a chap in London. It has been up and down the country, ending up here in the far north. As far as I know it has never been out of the UK.
Happy riding!
Kevin
650ss-tyre-and-dealer-plate01-jpg
