My lad has been moaning about the lack of brakes on the Atlas ,yesterday I rode it to check the forks which have been filled with ATF. The rear brake is total rubbish compared to the 99 which will lock the wheel if needed. I think the shoes were bought on E_BAY and were packaged as EMGO. Who does supply a decent shoe? ,trying RGM next.
I would think twice about…
I'm another satisfied cus…
I'm another satisfied customer of Villiers services.
Ian, did you contact RGM,…
Ian, did you contact RGM, about the problem? Obviously, they buy in the brake shoes, and sell them in good faith. If no one reports a problem, they have no reason to assume they are unsuitable. RGM are one of, possibly the best, suppliers of Norton parts, who?s speedy, and helpful, service cannot be beaten.
Previously John Shorter wr…
No I didn't bother contacting RGM, just put it down to experience. I've bought plenty of stuff off RGM and will continue to use them. The brake shoes are one of the few things I've had off them that I was disappointed with.
I am replacing my rear sho…
I am replacing my rear shoes which has a diferent material to the fronts ,anyone have experience of the gold linings?.
I am also considering the…
I am also considering the possibility that there may be a difference in the efficiency of the two types of brake arms, the dommy has the falling arm that in action pulls away from the leading shoe whereas the Atlas has a rising arm that pulls towards the leading shoe. There is a difference in the leverage point where the cam bears on the shoe. This changes the distance to the shoe pivot point. The two brakes are so different in efficiency like night and day. We will see how the Gold "high friction" linings work ,should be fitted in a day or so. Thinking about installing some extra grippy boot soles ,belt and braces.
Robert, This is most inter…
Robert,
This is most interesting. I've had my Mercury for about 20yrs now and have always been disappointed with the stopping power of the rear brake. I've noticed that earlier Domi's have the rear brake lever pointing downwards, whereas the Mercury has it pointing upwards.
I've looked at changing my set up for the earlier arrangement, but there doesn't seem to be room to pass the brake rod past the silencer. Please let us know if the high friction linings give an improvement.
Philip
Hi Phil, If the lever arra…
Hi Phil, If the lever arrangement is part of the problem, I would consider fitting a small bore siamese exhaust . Likely to be noisy though. Braking these old bikes is beginning to be a real issue ,car brakes have improved so much and some drivers habitually leave braking very late .
Previously robert_tuck wro…
Hi Robert - An interesting thought provoking thread. I have noted over the years of running Dommies that there are various lengths of lever for the downward types of levers whereas the upward ones all seem to be the same with the brake-rod positioned further from the brake cam. Could this have a bearing on your results ? In experiments I have done over the years with SLS front brakes I have indeed noted differences with forward and rearward facing brake-plate levers. Gold Star 8 inch plates seem to work better forward facing as do Seeley 8 inch. It is difficult to position the lever forwards on the Dommie 8 inch front but I shall do it sometime and compare. Cheers and good luck, Howard
Hit a snag ,the drum (with…
Hit a snag ,the drum (with 43 teeth) must be a commando item. it appears to be dimensionaly different to the 99 drum and has less depth and snags the side of the shoes,it needs a shim or different stub axle to work, could be a dud pattern part from the 1990's.I wondered why it needed an extra washer on the speedo side. RGM Gold rear shoes appear good if a fraction too thick ( to allow for drum wear?).
Hello Robert - The early C…
Hello Robert - The early Commando sprocket / brake drum has the same dimensions as the late Atlas/650SS but has UNF threads on the QD wheel studs for the sleeve nuts. I have interchanged Mercury drums with Commando and seen no differences whatsoever. The later Commando with the extra wheel bearing and cush-drive is quite different however. Cheers, Howard
Previously Philip Ham wrot…
Previously Philip Ham wrote:
Robert,
Philip
Hello again Phillip - have you thought about using a cable a la Commando? It's a simple enough job to fit an outer cable stop to the brake-plate and there are a lot out there at jumbles with the job done already (from cafe racers no doubt). The cable stop at the front is a bit trickier but certainly not beyond your expertise. I have also noticed on some of the late Atlas's, 650SS's and Mercuries that I have owned that there are different lengths of brake-rod pull levers on the foot pedal. Some of them were also at a shallower angle. I suspect that AMC knew about the problem of a poor rear brake and were experimenting with different set-ups. If there is any wear in the bush on the brake-plate because of the action of force on the upward brake-plate lever being further away from the cam it is translated into a bigger movement of the cam towards the action of the force - which is bad. So I think it's better to have the downward acting lever if there is significant wear between the cam and bush because it is closer to the cam. I wouldn't bother with a siamese pipe for the downdraught head. They are awkward to fit correctly and that nut on the rhs can't be replaced. Cheers, Howard
Found the problem, bent br…
Found the problem, bent brake plate. Later-- not the brake plate , the new shoes needed a bit of attention from the angle grinder to the width of lining and one of the end pads which was being trapped by the cam ,back to fitting.
Road tested Atlas brake wi…
Road tested Atlas brake with (fettled!) RGM gold linings, after a bit of milage will now lock the wheel. Result at last.
The early Commando sprocke…
Check out the attachment, which shows that the Commando rear brake/sprocket had 42 teeth. The Atlas had a 43 rear sprocket.
Not sure what the Mercury had. My guess would be 43. Bacon's Restoration Book says they were 43T but that would suggest Cycle sleeve nuts.
bike-specs-page-7-bmp
Just checked the Alas has…
Just checked the Alas has 42 ,so its a commando drum, and yes it has different threads to the dommy . Stupid change ,but must have made sense to someone at AMC.
I would think twice about the RGM brake shoes. I bought some for my ES2, which has the full width front hub, and they were like granite. I broke them in for several hundred miles and the trailing shoe had a contact area about an inch long and the braking effect was very poor. I gave up on them and had some shoes redone by Villiers Services. You can tell them what you use the bike for and they will use appropriate material for the linings. I've done a couple of hundred miles on the one's they supplied and the brake is much better already.
https://villiersservices.co.uk
There are instruction on their website as to what measurements they need.
Ian
