Hi all, does anyone know if the 750 or 850 interstate tank fits the 1971 750 fastback?
cheers.
Hi Peter that could be a g…
Hi Peter that could be a good idea can you still purchase (LR) tank.
Cheers.
I had a LR tank a good few…
I had a LR tank a good few years ago. It is a Dominator tank with a base for a Commando. The cutouts under the rear of the tank for the two down tubes are not very accurately positioned. When the studs at the front were lined up with the centre of the mounting holes the cutouts vibrated badly against the frame. I spent plenty of time moving the tank around and finally got rid of it. They come up on ebay now and again but you need a seat without ears on. It holds an extra gallon over the stock Fastback tank. Interstate tanks come in two sizes, some early ones (fibreglass)hold about 5 gallons and the later slimmer ones in steel, slightly less. Bear in mind that 5 gallons of fuel weighs about 40lb. The long range tank looks rubbish compared with the Fastback and 3 gallons should get you 150 miles! how far do you need to go between refuels?
Hi David thanks for that g…
Hi David thanks for that good info,i like the look of the slim line steel interstate tank also the seat i have on the bike when i got it has no ears
so hope if i can manage to get one to fit ok i am also going to buy new stainless steel guards and rear tail light.
Previously wrote: Intersta…
Interstate tanks come in two sizes, some early ones (fibreglass) hold about 5 gallons and the later slimmer ones in steel, slightly less. Bear in mind that 5 gallons of fuel weighs about 40lb. The long range tank looks rubbish compared with the Fastback and 3 gallons should get you 150 miles! how far do you need to go between refuels?
All the tanks will fit but for the Interstate bowser I think you'd need to buy a new Seat and rear mudguard (fender) and lights? To get better distance, why not fit a Long Range (LR) Tank which was designed as a swap out for the Fastback tank?
