This is the new thread seperated fron the 1953 ES2 electric start ?.
Right here we go !
This week i placed orders with RGM for the remainder of the gears bushes spacers etc that i didnt have and they arrived wednesday so now i have everything i need for inside the primary drive case. Then i spoke to Les at Novil in his happy hour what a character, and he supplied me with a New more powerful starter motor and three starter leads more thicker, and they arrived thursday. This morning i checked the battery to see what numbers were on it and there was none , so my guess its a cheapy. Towards the end of next week Nidge is coming over to make a start his only concern is the battery may not be up to it, and he said leave the ignition for now untill we try it.
Andrew.
Any idea if it is one of m…
Hi David, The starter moto…
Hi David,
The starter motor i have is exactly the same as yours in the photo , i am hoping it all goes together well without any more purchases, the old bills have been stacking up lately.
Kind Regards
Andrew
Previously andrew_windsor…
Right here we go !
Andrew.
Some electronic ignitions advance if the voltage drops. If when using the electric start the battery is not up to it the voltage drops to the ignition, the ignition advances causing kickback which can cause damage.
I would see how well the engine turns over with the ignition disconected while measuring the battery voltage. If the voltage drops too low replace the battery before starting. Motobatt batterys are good and have four terminals so you can use two for the starter and two for the rest of the electrics.
Hi, Thankyou Chris the poi…
Thankyou Chris the point you make is a good one , i am pretty sure the voltage was down when i experienced the kickback . i will put the voltage meter on it and let you know the readings..
Kind Regards
Andrew
Kind Regards
Andrew
I know costs can run away, but it is better to spend on a new battery than have a sprag destroyed as you probably have found they are not cheap.
I have fitted an early battery tray which allows a larger 21 amp hr motobatt battery, two terminals for starter, two for electrics. I use car battery cable and a mini starter solinoid with a Norvil starter motor. I am using a Pazon ignition from Andover Norton. I have used relays for all switching. This results in no hesitation when I press the button.
If you have an old starter solinoid check the resistance across the starter connections while it is engaged. My original had very high resistance probably due to bouncing when used with low battery power.
Hi, Just rebuilding the el…
Just rebuilding the electric starter i have got to the point of fitting the thrust washer and the three disc springs what tension do i need to put on the nut, it cannot fly off because there is a circlip in front of it.
Kind Regards
Andrew
Hi Andrew You are referrin…
Hi Andrew
You are referring to the preload applied to the anti-backfire device. The Haynes Manual says to tighten it until a torque of 50 ft/lbs will cause the device to 'slip' as the balls ride out of their sockets. You are going to need to make some adapters to hold it in a vice. Personally, I found that 50 ft/lbs was not quite enough and I set mine at 70 ft/lbs (NOTE: this is the torque to make the device slip, and not the torque on the nut)
That nut should be a new one so that you can peen it and lock it.
Several of us have said in this and the other thread to watch the battery. I am concerned about your opening comments and suggest that you must have a new, high current battery. Do not even try to use an old 12 or 14 Ah battery or you will have severe upsets. Test it on a 40Ah car battery if you have not bought one yet.
Norm.
Watch that the disc washer…
Watch that the disc washers are oriented the right way to create thrust, and not stacked together as a set of cones.
Hi Norman, I have got the…
Hi Norman,
I have got the thrust washer with the groove facing the ball bearings, i have put a slight smidge of lithium grease in the groove ? the three coned disc washers i have facing towards the thrust washer ?. I have been piecing it together from the diagrams out of the parts catalog . Can you enlighten on the thrust washers as i feel i might of stacked them. The nut is a new one in fact all the parts are. Today the new solenoid arrived . When you refer to peen the nut and lock it , do you mean swath it with two hammers gently.
Kind Regards
Andrew
Hello, I use for 4 years a…
Hello,
I use for 4 years a DEKA ETX 15 battery (made in USA,like Harley) AGM-frost,for my 850 MK3,105 euros in France.
Starting-up only with the starter and I am very satisfied.
This starter is the same sold by Norvil or David (made in USA also I thinck ? But I do not know who make it : Prestolite? Toyota ?).
My ignition is with contact breaker points,the Boyer is not recommended for Ã?lectricstart and even for the kickstart (kickback current
Hi Andrew I am working fro…
Hi Andrew
I am working from memory, and it is a few years ago, but the coned washers have to be stacked so that they have a maximum compressability. i.e they work if stacked like this <>< but not like this <<<. If you have just three of them and it shows three in the parts diagram then that is the number, but I cannot remember.
Peening the nut flange is with a flat faced punch (e.g. 2 to 3 mm dia) and a good belt with the hammer so that the metal distorts into the thread. You cannot loctite it because it takes a while to get the torque right, and the nut tries to move when you apply a test torque load! I have a thought that I might have put on a temporary lock nut to overcome this.
A better fix would be a hole in the shaft and a castellated nut and split pin. The circlip does not hold the nut still but I guess serves only to stop it falling off completely if it came undone; at which point the starter spins and there is no drive so no great harm done.
Norm
Have a look at Old Brits t…
Have a look at Old Brits technical article on the backfire device
shows you all you need to know - there are other very useful articles on the same web site - Alan
Hi, You guys are a wealth…
You guys are a wealth of knowledge, thank you so much, it is nice to know i am heading in the right direction.There is a groove in the backfire shaft so i can nip the nut into that . The larger of the two gear idlers runs very close to the front belt drive pully i guess thats how it is, not much room in there.
Once i am happy with the gear assembly and fitment, the next move will be installing the solenoid and leads, i have noticed a spade connector on the solenoid , and once the head scratching starts i will be looking for more help.
The upgrade for the electronic ignition is a must its just deciding which one to go for.
Many Thanks
Andrew
Tris-park it is a good Ã?…
Tris-park it is a good Ã?lectronic ignition for the comandos.
Here,in France,many Norton riders fit this ignition.
The trispark is quite good…
The trispark is quite good value for money at the moment with the weak australian dollar. Mine worked out at about £145 Direct from the maker
Hi All, An update , i have…
Hi All,
An update , i have torqued the backfire device to 70 ft/llbs and its refitted on the bike everything else is in place on the primary drive side. The next stage tomorrow fit the new starter solenoid and check there is power to the starter button, is it too risky to try and start it with the boyer ignition, i know previous posts have advised to fit the trispark first.
Kind Regards
Andrew
Why not rig up a separate…
Why not rig up a separate battery to just power the ignition. If it is a stand alone power supply then it's voltage won't be dragged down by the starter motor. If you want to test the system you could just connect a set of jump leads to your car battery. That will withstand the load and not drop the volts to boyer advance threshold. The reason bike starters suffer in this way, is the tiny batteries fitted. Bigger batteries = more cranking power and less voltage drop.
Hi All,
Kind Regards
Andrew
Hi Andrew,
Is it wise to set the torque to 70 ft lbs if the manual recommends 50? I know that some owners have needed to go higher than the recommended figure, but this has usually been after trying it out first.
It seems that certain combinations of sprag/sprockets have more or less wear which can be worked around by increasing the torque setting on the backfire device.
If you have new parts fitted, it may be better to start with the factory setting. Your call, of course! I am part-way through re-installing the electric start on my Mk3, so I'm watching this thread with interest.
Allan.
Hi Allan, I went for the h…
Hi Allan,
I went for the higher torque setting as i felt the extra 20ft/lbs might help with the cranking over. From past experience 20ft/lbs of torque you can nearly guage it with just a normal spanner in your hand its not much. I am committed now, with the nut peened etc so its run the gauntlett and go for it !
Kind Regards
Andrew
Hi All, Electrics not my d…
Hi All,
Electrics not my domain.
I have three leads , One long red lead ,One long black lead, and a short black lead. One terminal on the starter motor. I have rewrote this post several times with combinations of how i think where the leads will go , and i keep coming up with different scenario"s so i guess its best let you guys tell me .
Kind Regards
Andrew
Hi All,
Kind Regards
Andrew
Long Red:- Battery positive to engine crank case stud fixing top back infront of starter motor.
Long Black:- starter solinoid to starter motor.
Short Black:- starter solinoid to Battery negative.
Thanks Chris , there is a…
Thanks Chris , there is a spade on the side of the solinoid will that be to pick up off the starter button ,or it might be for an auxilery.
Kind Regards
Andrew
Hi All, A couple off hours…
Hi All,
A couple off hours in the workshop this afternoon still hopping round on one leg, ive about mastered it now . I fed the live lead under the starter motor and attached it to the upper crankcase stud just behind the left hand cylinder, a little bit of drilling on the live spade it was not big enough to go over the stud. The earth was then fitted to the starter motor the long one, and then fed up to the solinoid , and then the shorter black earth dropped down from the solinoid awaiting the battery. Just still waiting for the sump socket to arrive so i can drop out any excess oil . I have being charging my old battery up with the intension of using it but now i am getting closer to lift off the nerves are kicking in a bit so i will get a new one. Bare in mind this has been a blank canvass for me and without the help from you guys it would off been a nightmare. I wont thank you all yet untill i have finished i dont want you running off !
Kind Regards
Andrew
Hi All,
Kind Regards
Andrew
Do not forget its positive earth
....... Just still waiting for the sump socket to arrive so i can drop out any excess oil ........
Andrew,
You can drain the sump by removing the 9/16" AF drain bolt (which should also contain a magnet), just forward, and at a lower point, to the larger sump plug,
Regards,
Simon.
Thanks Simon, I have drain…
Thanks Simon,
I have drained the sump with the 9/16" drain bolt i will post the results on the Wet Sump - Quantifying forum . Just organising the heavy duty battery today i am trying to go for the four terminal one . I put the primary drive casing on last night i have to do little bits at a time then rest my leg . Just got the gear shifter to fit then the left hand footrest.
Kind regards
Andrew
Hi All, An update . Batter…
Hi All,
An update .
Battery connected all leads in the correct place , power at the ignition no power at the starter motor. So this morning seat came off also the fuel tank a least now i can follow the wiring around the bike. The front of the headlight will also come off looks like thats where the wiring congregates .
Andrew
Hi, Got a temporary power…
Got a temporary power supply to the starter motor it spun over fairly quick but, something not right. though.
My old mate tot then used the kickstart to turn it over it seemed liked the starter was fully engaged. Tomorrow whip the primary casing off and have a look , still trying to get my head round how this lot works. The anti backfire device torqued to 70ft/lbs i think maybe back it off to 50ft/lbs and see if it makes a difference.
Andrew
hi if the starter motor ru…
hi
if the starter motor runs at speed but does not engage and turn the engine over but the starter turnes on the kickstart the sprag clutch needs turning the other way round it fits boath ways.
regards
bob
Thanks Bob will turn it ro…
Thanks Bob will turn it round, the story of my life being left handed "LOL"
Kind Regards
Andrew
Hi. Ive taken the primary…
Hi.
Ive taken the primary outer casing off for inspection and spun the starter over and with 70ft/lbs of torque we are slipping with a slight engine turnover. Do we increase the torque or is there something else i need to look at.
Kind Regards
Andrew
hi Andrew take boath spark…
hi Andrew
take boath spark plugs out push the kickstarter down does it turnover freely with the starter gears staying stationary.
is the bike wetsumped have you drained the oil out .
if you have checked the above i would re check the backfire device are the six ball berings round or worn oval ......
regards
bob
Hi Bob, On turning the eng…
Hi Bob,
On turning the engine over with the starter motor the gear crank is slipping and then on the odd occasion grabs the crank for a second then slips. I took the spark plugs out turned the engine over by hand and the starter motor is fully engaged . All brand new parts have been used on the rebuild including the ball bearings.
Andrew.
Hi Are you now saying its…
Hi
Are you now saying its slipping on the crank (sprag gear) or is the backfire device slipping.
www.oldbritts.com/e_start_gears.html
regards
bob
Hi, Its slipping on the cr…
Its slipping on the crank sprag gear.
Andrew
Hi Check all the sprag tee…
Hi
Check all the sprag teeth face the same direction and one is not flipped over or the sprag is faulty or the gear the sprag runs on is under size.
ive neaver had one slip and thats what the backfire device is for .
perhaps somone else can shed some light on this problem
Bob
Hi, I would like to thank…
I would like to thank everybody for there help. I stripped back down on the crankshaft side and realised i hadnt fitted the most crucial component the sprag gear that grabs the front pulley. I had the part but miss took it for another bearing .
Signing off on this post
Kind Regards
Andrew
Any idea if it is one of my starters?see here:
IF so...I have tested it with an atlas battery, regular commando battery, and of course the regular lead acid yuasa E-start battery. and they all work just fine on the starter. But the old boyer analog does not usually work well with a stock starter, mod 4 brush starter or my starter. I currently use the stock size yuasa AGM on my MKIII (my starter of course).
