I am a new member and wanted to ask if anyone has replaced the exhaust rose with stainless steel versions?
I am just concerned that the Stainless may fuse with the alloy head. Or can someone recommend something that can withstand the heat, such as grease to enable me in future to be able to remove?
Thanks Simon
I use the Bronze ones, clo…
Previously john_holmes wro…
Previously john_holmes wrote:
I use the Bronze ones, closer coefficient of expansion to aluminum alloy so less likely to loosen and do not rust. Stainless has its uses but can't see any advantage on these nuts over bronze and instead see a risk of threads stripping from seizure.
Thanks my thoughts as well
I use Bronze ones and Copp…
I use Bronze ones and Copper slip on them, re-tighten when hot.
remove when hot.
Previously christopher_win…
remove when hot.
I use some stainless as well, been doing so for years with no issues. The trick is as above, most especially when tightening the hotter the better.
