Has anyone got a pic of the right hand switch 'cluster' with the top section stripped down (Head/ Pilot). I think I am missing a part. I did take pics on the strip down but not with the screwed plate off. I know there is a ball bearing and spring that is held in place with the slide switch protruding through the casing. I have the cable that slots into the casing but feel I'm missing a small nylon/plastic piece.
Also is it possible to get ignition keys. The 850 project I have bought has the ignition switch but no key. Is there a number on the barrel somewhere that I could use to get a replica cut? or has anyone got one for sale that is useable?
regards
Mike, iiirc it's the same…
Attached photo of top of R…
Attached photo of top of RH switch for mk3 - ball is 4mm dia, spring is just over 3mm dia & just over 7mm long - within the large nylon piece, there is a metal U shaped item that sits in a channel in the nylon that moves across the contacts on the PCB - please let me know if you require any spares as I have several of these switches culled from Ebay - Alan
rh_sw_top-jpg
Previously Alan Sessions w…
Alan many thanks for the pic. Could I take you up on that offer. I have turned everything upside down and can't find it. It's definately in the picture I took before I stripped it. I will need the nylon piece, spring and ball bearing. I have the U shaped item. Obviously I expect to pay for them
regards Mike
Hi Mike Please email me yo…
Hi Mike
Please email me your address and I will post the 3 items that you require : alsesh@aol.com
Cheers Alan
Mike,
iiirc it's the same as the left hand side (Main/Dip). Ihave a vague memory of a spring & a ball bearing in a nylon block under a metal strip (long time ago when I looked - dinosaurs still roamed the earth).
I can't check mine as it's at the shop having the smoke put back into battery & wires.
Mk III
