I am almost too scared to ask, but I may need some new tyres soon, I have
Almost worn the rear one out. Any one tried anything different to the
dunlops? I am an avon tyre fan. Should they wear tyres out? (Joke)
clive Willis
Hi Clive After 3000 miles…
Hello Clive, I have fitted…
Hello Clive,
I have fitted Bridgestone S20s as well - so far so good. The Dunlops had both had their day after 3000 miles.
I found the Dunlops started to affect the steering after about 2000 miles, it became increasingly "heavy". Anyone else experienced this? Is it a "Cafe Racer thing" or does it affect the sport as well?
Raphael - have you stayed with the factory recommended tire pressures?
Dave
Hi Dave, Yes I stayed with…
Hi Dave,
Yes I stayed with the factory recommendations.
Do you see a reason to use other pressures?
The Bridgestones seem to keep a bit more than the 3000 miles. But since I changed from the Dunlop tyres my way to work changed as well and is (unfortunately) less curvy now...
Raphael
Previously raphael_vonaesc…
Previously raphael_vonaesch wrote:
Hi Dave,
Raphael
Hi Raphael,
No, I don't see a reason -justcurious. I ran the Dunlops at 36/42psi for a while when the steering started to get heavy. Initially there was a slight improvement but I went back to 34/38 . All my other bikes I have run at 36/42 after changing the OE tyres.
Dave
Previously David_charleswo…
Hi Dave,
Raphael
Hi Raphael,
Dave
Hi Dave Ralph and all,
What I found out is anything less than 34psi in the frontand 38psi on the back is asking for trouble.I had well under 34 in the front the other day and the handling was all over the place. The other thing I found out was that normal tyre inflaterlance type fittings just don't work on the Norton.You need a flexible or 90 degree fitting to blow your tyres up. This is quite important to note! if you are going on a long journey take the right bit of kit with you. It caused me to be late at Norton for my service last week.
Hello Dave, Thanks for the…
Hello Dave,
Thanks for the tip I'd never even thought that I might need to blow the tyres up other than at home!
I completely agree with you regarding 34/38 being "minimum" pressures.
Dave
Previously david_charleswo…
Previously david_charlesworth wrote:
Hello Dave,
Dave
Hello All I noticed the same issue with valves on my Ducati and when I had the tyres changed had 90 deg valve stems fitted and will do the same when I change tyres on the Norton. hope this is of use
Paul.
Anyone fitted the Bridgest…
Anyone fitted the Bridgestone S20 Evo's yet? I've got S20's on at the moment and if I'm lucky they might see 3000 miles, they've done 2500 already so it's time to think of a replacement. If the Evo's give more mileage they might be worth the extra - not that I would expect that much more as they are still a soft compound. Otherwise I'll be sticking to the S20's.
Hello Clive,
Dave
After 2000 miles my front end felt heavy. Changed tyres to michelin pilot 3 & now feels like a new bike.
Hi Clive
After 3000 miles with the Dunlop ones I did putBridgestone Battlax S20 Hypersport tyres and am very happy with them... Soon I need to look for new ones again
Raphael
