Whilst I`m waiting to get the same info from RGM ( left a message as I cant get an answer ! ) Could someone advise what type of Alternator Stator is right for my 1959 Dommi 88 500cc ? I want to eventually run LED lights and maybe indicators in the future. I have bought a Tri-Spark electronic ignition kit also and found a note with the fitting instructions recommending to use a Mofset 20amp Voltage regulator / rectifier as my Podtronics single phase voltage regulator would cause noise interference severe enough to affect the electronics. I intend to buy one as advised but need to know if a certain type of Alternator Stator is required ? Is it advisable to purchase a new rotor at the same time too ?
Can't advise on new…
Exactly
The original stator would have had a 70mm rotor (and stator to match) but this size rotor/stator or no longer available as new. So you are stuck with the later 74mm rotor stator, the basic item being the RM21. LED lights will reduce any demand for electricity, while indicators are intermittent usage (maybe even LED) so hence are not to worry about, With regard to rotors-these are magnetically /electrically all the same, but with age the rotor might be coming apart and its magnetism can reduce, can be tested (see my web site). Only other area of concern with regard to running indicators 'on all our bikes' is to make sure we have a decent battery, none of the 'gel' ones from the alarm world, but something with reasonable AHR ie you can get 7Ahr and even 9Ahr in a Dommie battery box.
With regard the reg/rect recommended by M Ball, we do NOT know if this is for permeant magnet rotors, and it is for 3 phase this is not for use on an RM21 (single phase) My advice is stay clear of this item unless you KNOW what it is for and how it is meant to be used. ie on specific Hondas
Batteries question ?
Hi Alan , would you not recommend a Gel type battery and what is meant by the reference to `Alarm world ` . Thanks for your input .
The generic Chinese "CBR600"…
The generic Chinese "CBR600" reg/rec I linked to is in use by me on a permanent magnet, single phase alternator. I've fitted and used a few. Many other old bike riders use them. They perform well and last well. They show precise voltage control and don't get hot.
That's why I recommended it. I'm surprised Al Osborn doesn't know about them.
As my alternator is single phase, one of the reg/rec's yellow wires is not connected. Some people connect two yellow wires together to one of the alternator output wires.
It might even be worth an expert's time running a few tests on one. After all, it's not a big investment at £11.53.
Back to stators
The early Indian Enfield Bullet stator would appear to be dimensionally correct. Try Hitchcock's for advice and supply.
wow thanks !
Thanks to all for the feedback . It`s been worrying to not know whats going to work with what ! I did get to talk with Roger at RGM yesterday who put me straight about a few things ( nicely ) and made me think about if I would be riding much on dark winter nights anymore or just a nice buzz around on warm sunny summer days . I will probably go for the Mofset reg/rec as advised by the Tri-Spark makers and RM21 alternator Stator and new Rotor as Alan and RGM Roger suggested . I bought the bike as a part built cafe racer but found it had been chucked together . Hours of work has gone into sorting it with a good deal of cash being spent . It has a 74mm rotor and a tatty looking Stator that might work but I dont want to spoil it `For a h`ap`orth` of Tar `! Need to know more about Batteries now .
If the tatty old stator is…
If the tatty old stator is the type with exposed coils, it's a fair bet it would fail at some point.
It`s tatty but enclosed …
It`s tatty but enclosed . wires coming out are not nice. Rotor is date 11 72 so will probably be weak too .. Not worth taking a chance I thought .
Gel batteries!!!
This is the colloquial name to the very 'square' cornered batteries that have 1/4 Luca terminals, they are made for the burglar and fire alarm world. They are meant to be float charged for a long time and have a lowish limited charge rate (depends on the Ahr as to how much) If they ever get over charged for any length of time they will dry out and fail. They are not meant for Automotive use, which is highish short term charge/discharge. Our bikes were made for the Flooded acid type which when they overcharged (the earlier 6V) would tend to boil off, (you then topped them up). The gel type if they over charge dry out and fail-end of. AGM seem to be very good for our bikes.
The bike actually came with…
The bike actually came with what I now know (thanks to you ) one of these Alarm batteries . I thought it was odd having spade connectors ! Funnily enough I have had exactly what you said would happen with a Gel battery. The rec/reg failed and it overcharged and failed leaving the battery Bulging on the sides ...This being on another bike though.
Bigger Ah, the better!
I wouldn't go for less than a 6Ah battery.  More capacity, the better. Traditional lead-acid or gel. I dropped one bike twice and never had a problem with acid spill on the old Lucas batteries!  Perhaps I led a charmed life when I was younger! :-)
Yuasa are an excellent make and their 6N11A-3A is 11 Ah (!!) and only measures 122mm long x 131mm high x 62mm deep. Their website lists them at £39.55.
Of course, you can get a Powerline 6Ah, AGM battery (6N6-3B) for £13.47 from eBay.  I have no idea how good they are, but I would prefer a capacity closer to the old Lucas batteries in the 1950s and 60s. The PUW7E in my 1952 Lucas catalogue lists them at 12Ah at the 10 hour rate! I've copied the relevant page here : -
Just recharged the Yuasa…
Just recharged the Yuasa acid battery that has been neglected for a few months on my out of use 250 Ducati that i used for the IOM for many years. The Voltage slowly raised to 14.4 . I then noticed the date on the side 2001. thats right 24 years old.
Some facts....
Fact eBay does not sell anything-eBay is an auction/buy it now site, for merchants, you do NOT buy from ebay you buy from the appropriate merchant.
Regarding batteries on our bikes- yes 5Ahr is my consideration as the SMALLEST you can fit. Anything smaller will over charge on a decent journey 'over 50 miles' if you have 9 or 11Ahr you will have reserve, when you use the indicators to turn with engine at tickover, When you leave the lights on, when you stop at the lights with the brake on-AHR will help.
Don't expect the 'wonderful' Automate type battery charger to charge an older tired battery-use an 'old fashioned' battery charger and leave it on for a good few hours at a few amps. The 'stupid' automate type monitor's a high voltage and the LED goes Green, but there is no AHR behind it.
Taking your advice into…
Taking your advice into account I will be looking for something around 9Ahr of the right dimensions . Motobatt do a 8 Ahr AGM about the right size I am considering But still searching !
three wire stator to V Reg 2
If using one of Al's magic regulator boxes, do I just connect the alternator WG and GB wires to the V Reg 2 inputs? What should I do with the stator GY wire? Does it just dangle in the wind (figuratively) or does it need to be connected in with one of the other wires (presumably the GB).
Over to you Al!
The instructions are with the a Reg
Don't tell me, you have lost the instructions......All A regs come with proper instructions. If it was a two wire stator you would have to use the WHR/GRN and the GRN/YLW, so they are the first choice.
The GRN/YLW being the High Output with respect to the WHT/GRN. The GRN/BLK being the Low output joins with the GRN/YLW for full out put-we all know this!
FIling system
Is of course random access. The instructions are probably around somewhere...
Thanks for the explanation!
I can't......
I can't be responsible for your filling system, you get proper instructions but you loose them!
You can lead a horse to water but you can't make it drink. Fools 10 a penny.
Good to know you are still there Gordon, perhaps the instruction above is helpful to others!!
Can't advise on new alternators.
These are good regulator/rectifier boxes.
https://www.ebay.co.uk/itm/317112493018?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338778191&toolid=10001&customid=130832X1595795Xd14bf1860384640515ca137e80f32af5&subId2=15
Plug and wires.
https://www.ebay.co.uk/itm/317112536052?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338778191&toolid=10001&customid=130832X1595795X7f503c9c8f3b448b6ff978debd99bab4&subId2=15
