650SS wrong gearbox
Hello
The 650SS cafe racer that I'm restoring has the wrong gearbox. Its the AMC 1 box. I believe that all 650SSs were fitted with the AMC 2 box. I'm just wondering if this does have a noticeable difference in performance with an extra tooth in 4th on the mainshaft and extra tooth in 3rd on the layshaft. Its not that its going to be raced or thrashed but would be nice to ride it to its potential now and then.  I know very little about gearing and how it effects performance but as Norton thought the AMC 2 set up was right for the 650ss then I'm thinking thats how it should be. I'm aware that its possible to convert to AMC 2 spec by swapping the paired gears but this comes at a price at a time when Im nearing completion of the bike with a budget blown apart (as always). I might have to live with this at least for a while but would be nice to know how this difference effects things.
All the best
Gary
The mainshaft doesn't have a 4th gear. What it does have is the sleeve gear (that has the drive sprocket attached) Top gear (4th) is direct drive (1 to 1) through the box as that has the least transmission losses. Even if you did swap gears about (and good luck with finding them!) you would notice little-if any difference in the lower gears, top gear would be the same.
Worry about something else, like how to get 1960's air in the ancient original tyres.
Thanks for your response Peter and thanks for putting me right regarding gearing. I've done a fair bit of research now on this site and others which tells me exactly how a Norton gearbox works but reassuring to know that the difference would be neglible except perhaps in 3rd.
Hello Gary - the 650SS (and Atlas) used a gearbox with the number pre-fix "NA" whereas most of the slimline Dominators had a pre-fix "N".  As you quite rightly say the 650SS ratios are commonly known as AMC2 set.  The layshaft 4th gear had 23 Teeth rather than the previous 24 Teeth. This raised the ratio of the first three gears and reduced the large gap between third and fourth gear.  The raised gearing of bottom gear wasn't a problem when pulling away because of the increased power output.  Obviously swapping the gearing from AMC1 (pre-fix N) to AMC2 (pre-fix NA) requires the pair of gears to be changed together.  As well as the gear ratio change, the kickstart spring on the NA gearbox is much heavier and more reliable. Unfortunately the springs are not interchangeable.  The kickstart shaft, inner and outer covers must be swapped to use the heavier spring.  I suggest you have a read of the Dominator Service Notes on the website library particularly Chapter 10.  My notes here summarise the salient points of your query from the DSNs. If you do swap the gear pair you can fit Atlas, Mercury and early Commando ones.  Additionally all the Dominator bikes built at the Matchless factory in Plumstead had the NA gearboxes.  Good luck, Howard
Thanks for your informative response Howard. What I've decided to do is go ahead and put this gearbox together fully restored and put it in and use it. I have 3 Norton gearboxes amongst a load of Norton stuff accumulated over the years by my late father and myself. I know that they are early boxes because I know what bikes they came off and sure enough they all have the N prefix. So once I've finished this bike I'll sell off the stuff I don't need and then think about buying or converting to AMC2. If I have an issue with AMC1 box that is.
Howard has miss quoted the Layshaft 4th gear tooth count. It is the Sleeve gear that has 23 teeth, (or 24T if the earlier box) the layshaft 4th gear has 18 teeth (to match the 23 tooth sleeve gear) for the later AMC box
Looking at the gear chart on page 134 of the Heavy twins compendium it has the sleeve gear @24T and the Layshaft 4th @18T
AN supply two types of 18tooth layshaft 4th gears, this is because the tooth form is slightly different, one of them is to engage with the 24 tooth sleeve gear.   .
Howard is spot-on with his information and suggestions.  The Gearbox section of the DSNs is packed with facts, figures and useful maintenance hints.
Adding a few more important notes to this thread.
The Norton 650 road bikes with NA gearboxes first appeared from May 1962 onwards.  So these would be Bracebridge built 650s. The first being 18  103021 with AMC 2 box NA 1044.
But typical of Norton production  650 bikes with boxes stamped with lower NA numbers were dispatched later. The lowest recorded being NA1003.  The majority of the first 1000 NA stamped gearboxes heading off to decorate Manx Racer frames.
As 650 production began with bike 18 93601 there were quite a number that left the Bracebridge  factory with an AMC 1 box.  Possibly over 1500.
Even the first Atlas bikes were fitted with AMC 1 boxes. The first Atlas kitted with an AMC 2 box being 20 103639 in July 1962.
Surely this is a case of not 'what was originally fitted' but more like 'what is currently fitted' is it a 650SS or Cafe racer, the latter could have a variation of the parts fitted from whenever.
If I had a pound for everytime someone had rang me saying that I have sent the wrong part to them I would have retired ages ago. The call usually runs along the line of 'I sent the part for a 19xx Norton Dominator' but then get the reply 'it's actually a Cafe racer / Triton etc' usually followed by it's an original cafe racer or Triton.
The Dominator Service Notes table of gear teeth appears to be incorrect for AMC2.
The mainshaft sequence is listed
21, 18, 14, 23.
Other publications list
23, 21, 18, 14
Well spotted Dave.  Definitely a rogue number in the list.
The final 23 should prefix the queue of mainshaft digits and actually read......
23   21   18   14
Very strange , i was sure my 99  assembled in 1959 has an AMC2 box.  And also my spare box of similar age  Going to have to take one  down to check.
As Ashley says......there is no guarantee what you will find jnside a dismantled gearbox.
The Gearbox records are pretty accurate but even these are prone to Factory fiddling. It does not take too much engineering to change the ratios of both AMC 1 or AMC 2 gearboxes to assemble a close ratio set for Clubman racing.
Bracebridge assembled a good number of Special Sports Dominators with twin carbs, polished innards and possibly special gearbox gear ratios.
I converted my own AMC 1 box to  AMC 1 1/2 by dropping the sleeve gear down a tooth to 23. Easy to do and consequently making a huge improvement to the lower ratios.
The photograph shows the starting point being a box of bits.
Gearbox
