Hello, have Norton gearbox in N15CS
Took off the outer cover to get chrome plating striped
I have not disturbed the inner cover
Took out the Knuckle Pin from the Change Quadrant, no problem
No mater how much I try it will not go back in, the quadrant fork is to low
Is it normal to be able to take the roller in and out without taking off the inner cover
If so is there a trick to putting it in
Thanks Richard
knuckle pin roller
Thanks for reply, how I got…
Thanks for reply, how I got it out is a mystery.
Manage to just raise the inner cover to get the roller in
But something went wrong "click" and now covers wont come together
Guess I will have to take it apart tomorrow
Richard
Rotate the rear wheel and at the same time try moving the quadrant up with a screw driver or a lever (into a different gear position).
That may give you enough room to refit the knuckle pin roller.
Normally the knuckle pin roller has to be in place before the inner cover is refitted.
Good luck
