Hi, I'm having trouble finding a new headlight rim for my 1946 Model 18.
The light unit is 7" diameter and the diameter of the casing is about 3/8" smaller and the rim "tapers" front to back. The rim is fixed by a quick release sprung clip mounted on the casing which "hooks" through a hole at the bottom.
Can anyone suggest a supplier?
Thanks,
John
Sounds a bit like a Miller type. Try Grove classics or a velocette supplier.
