Hello All,
I'm hoping someone can help me find the correct speedometer for my 1950 Model 18. The one I have is a 120 mph unit, but is fairly accurate, at 1475 revs/mile. I also need a bottom-pull trip reset, as mine is a side pull.
I would be grateful for any information as to purchasing or rebuilding the correct unit. I lived with it the way it is for 40 years, so now might be a good time to put it right. Thanks for your help.
James
James; These people are…
Chronometric instrument…
Chronometric instrument services (chronometrics.co.uk) has a big stock, and there are several others. Your 120mph instrument might well be more valuable than the 80mph version.
I set up a spreadsheet when I was looking for a speedo and by my calculation, if it is geared to 1475 turns per mile, your instrument will read 5% fast if you have a 21" rim and 3" section tyres. I think the only Norton matching that will be prewar Inters (model 30 and 40) or post war Manx and 500T. Yours comes out 14% fast.
Hi James, most Nortons were…
Hi James, most Nortons were set to 1550TPM on the speedometre.
As fr the side trip, your can be changed over with the correct parts. ODO shaft with the fine gear and the side trip assy with input shaft.
If you have any other questions happy to help.
Steve (Australia)
instrument repairer.
James; These people are Smiths. Website: https://vintagebritishcables.com/
Great to work with and reasonable prices with fair trade-ins. Mark
