Hello. Hoping someone could advise me on where and which pipes go where on a Jubilee.
I have a manual and it is very basic,but does say the outer pipe on the union from the engine is the feed pipe. on the oil tank there are two small bore outlets,are the rockers fed from the one that branches out at the bottom of the oil tank,and is the other small one at the top of the oil tank a breather.
The Jubilee is a project and has no oil pipes, just the dual union from the engine.
Kevin.
I recolect an article in…
Go on Robert ..... you know…
Go on Robert ..... you know you want one really!
Oil lines - I used this information
Is there any way to print…
Is there any way to print that Roadholder page? It shows as a blank page if I try to print, download,. save, etc.
Jack
I can’t print it either, I’d…
I can’t print it either, I’d suggest doing a screen grab, ctr print screen if you are using a pc. Or the home and off button on an iPad.
I recolect an article in Roadholder with a detailed diagram of the Jubilee pipe layout. If I can find it!!. Later,Page 42 May 2004 go to Roadholder Index on this site. Thats a bit worrying ,can't remember what I had for dinner ,but can remember Jubilee articles, never even had one!!.
