Hi All
where can I get new sprockets for my 1929 model 18 Norton....I want to replace all the Drive Sprockets so they're all new and pointy...so that's the
- Magneto Drive Sprocket
- Gearbox Final Drive Sprocket
- Wheel Drive Sprocket
- Clutch basket and Sprocket
- Crank Drive Sprocket
the main one I'm after is the Primary Drive Sprocket / Clutch Basket it's all in one but while I'm at it I might as well replace the lot whilst on the Clutch anyone got an idea where I can get new plates will sureflex plates do the job / fit ? thanks in advance Russ
I had a similar requirement…
www.racingnorton.co.uk …
www.racingnorton.co.uk No se si tendrán tu modelo (1929 c s 1)
Debes ajustar los conos con pasta de pulir.
La cadena era marca Renold,
Saludos Gerardo.
I had a similar requirement for my 29 CS1. I couldn’t find a supplier of new sprockets so used John Hemming Engineering 01547 530759 who retoothed the existing sprockets. Did a good job but be warned the cost does add up.
Alan
