Horn push washer
Forgive my abysmal ignorance on matters electrical guys but where does the insulating washer inside the horn push button on a mid fifties single go? Just under the cover at the top or between the handlebar and the unit?CheersGeorge
Oops. Should have noted the horn push button also combines the dip and main beam switch. George
Stand down guys. By a mixture of poring over the wiring diagram and trial and error it is now obvious that the washer goes between the switch unit and the handlebar. I was trying to detect a short which prevented the main/dip to work. It was doubly difficult to track as the there was also a dodgy connection at the new (!) sealed beam unit. All sorted. George
