Dominator Boyer Bransden problems
I am getting an intermittent fault with the Boyer electronic ignition
on my Dominator.
Sometimes I get sparks when I turn the ignition off or on and
this can detonate the fuel left in the cylinder.
Sometimes it works with no problems.
I have double-checked the circuitry and am at a complete loss. I tried
taking the two wires which go to the stator plate and tried touching
these/taking them apart.
This produces sparks repeatedly so it seems to me that the coil
circuitry must be good or I wouldn't be getting any sparks at all.
Any suggestions would be gratefully accepted.
The bike was lying idle for some five years until recently when I
re-commisioned the bike, but this missing sparks problem has
me completely beat.
I would almost guarantee that your problem is a tarnished ignition switch. Or depending on the particular ignition switch your could have loose rivets if you have terminals on the back. But either way investigate the switch.
I thought getting a random spark was normal when turning a Boyer on and off?. or do I have a problem too?.
Sparking when switching off is also normal with Lucas RITA. In fact it's the easiest way to test that it and the plugs are working. As Robert says - nothing to worry about. It should happen with regular old fashioned coil ignition - switching off is what the contact breaker does. RITA (and Boyer) just amplify the result.
