Norton Jubilee, front mudguard brackets.
Hi my new pair of stays arrived today for my Jubilee, where they are threaded should the threads just screw into to bottom of the fork leg, i thought before i ordered them that the threads should be long enough to go into and out of the other side of the fork leg so that a nut could be fitted, but the threads are probably long enough to go half way.
Any help would be great, alvin@manx.net
The stays also act as cotter pins to lock the axle in place. The threaded end protrudes through the fork leg and is clamped by a nut.
