Noticed small oil leak into the primary chain case. Only leaks when the engine is running.
Where would it be leaking from.
John.
Just had to do mine, itâs…
Just had to do mine, itâs a relatively easy job so long as the old seal wasnât peened in too well! The club has them, buy two, as you might damage one in the process! No need to split the cases, but you do have to remove the clutch, stator and rotor.
Dan
I needed a puller to remov…
I needed a puller to remove the primary sprocket.
I made a puller for the sp…
I made a puller for the sprocket, it has threaded holes and a two legged puller on the rotor. Both came off easily enough.
dan
Thanks Dan. Would know the…
Thanks Dan. Would know the part number for the oil seal.
Thanks again
John.
If you look at the menu on…
If you look at the menu on the Lhs, go to noc shop, then click on catalogue, then lightweight, then seals and itâs on the first page. You could do the seal behind the clutch at the same time while you are in there, and even the sleeve gear seal if you are really keen!
Previously john_dunn1 wrote:
hello your leak may well be coming from the main shaft oil seal with in the clutch case hope this may help yours anna j
