Re: Featherbed frame number.
Hello, I have recently acquired a Norton rolling chassis with a Honda 4 engine "squeezed in".
Luckily there has been no alteration or cutting of the frame and my intention is to separate the engine and hopefully get a replacement Norton engine to start again.
My question concerns the frame number which is 64443. My research leads me to the conclusion it is a 1955 frame...... Would you agree with this, and would I be able to find out which engine would originally in the frame?
Many thanks, John
The model number for the frame was stamped above the frame number. So it could be a Model 88 stamped with an M122 which isa 500cc twin. This number is stamped on the lug at the back of the frame that the swinging arm attaches to.
Many thanks, John
Hello Now it's 64443 and what else there should be a stamped letter like K122 For 1955 model 88 yours anna j
Thanks for the information. It is K122, 64443.
Could you also advise on the model the fibreglass tank in the photograph could have been on.
Thanks, John
Thanks, John
Looks like one of the aftermarket tanks sold for triton builders by Unity Equipe.
Many thanks, John
4 in a bed, it's been a while since I've seen that!
Previously ian_cordes wrote:
K122 for 1955. It would be a 500 model 88, as previously mentioned.
Well the frame could have been a very early model 99 has the model 99 come into being in Septemberof 1955 but after seeingthe photos you can see under the paint and crud you can just make out K122 Yours Anna j
