Early AMC kick start stub shaft P/No?
Afternoon All
I have a 57 ES2 withan AMCgearbox S/No N4107, (pre 62 type) and need to replace the kick start stub shaft, my dilemma is that there seems to be several types out there.
I can rule out the Mk 3 and post 62 NA types with the type of return spring that hooks on to a peg.
That should narrow it down but I can stillsee two types namely 066169 and 040114 which are marked '1957 on ALL AMC' and 'AMC pre 62 with bush' respectively.
Are there any dimensions I could check that could identify?
Any help greatly received!
Brian
