The wheels have been previously dismantled and are now ready for re-assembly, what would be the
off-set of the hubs ?
kind regards
George Roland.
Hi George What year is you…
Previously roger_deadman w…
Previously roger_deadman wrote:
Hi George
What year is your ES2 is it rigid ,plunger swing arm or featherbed frame
Regards Roger
Hello Roger,
It's a 1952 plunger
Hi George will measure the…
Hi George will measure the offset tomrrow and let you know
Regards Roger
I think the RGM website al…
I think the RGM website also has the offsets? https://www.rgmnorton.co.uk/csi/1245184/f/pdf/wheel_offsets.pdf
dan
Doesn't include plunger a…
Doesn't include plunger as far as I can see......
I presumed they were the h…
I presumed they were the half width hubs, but Iâm no expert!!
No, they're symmetrical "…
No, they're symmetrical "cotton reel" type but different dimensions to the rigid ones.
I've just popped down to the garage and measured mine and on the speedo side the offset is 1.977" (probably a round 2") from the speedo driving boss to the edge of the wheel rim.
Previously ian_soady wrote…
Thank you very much for that , is the off-set only on the front wheel ?
Rg George Roland.
That's the back wheel as…
That's the back wheel as it's quite different to the front. I think the pdf from RGM has the single sided front wheel in it.
I have just completed a Pl…
I have just completed a Plunger front wheel rebuild. I purchased the rim and spokes from a reputable company as the drum is a half-width job that needs two separate spoke lengths. Because the spokes were exactly correct, the task was very straight forward and I ended up with an almost concentric rim that sat centrally between the forks.
As far as I know, except for a few specially built racers, all of the frames using Roadholder forks had a centrally positioned front wheel with no off-set.
Hi George
Regards Roger
