Restoring a 1956 dominator gear box I believe to be a Burman serial No. GB8 6585 am I correct ? Gear lever very sloppy is there a fix for this and are parts still available. The clutch operating rod which goes through the majn shaft to the clutch is there a small ball bearing between the rod and the mushroom headed push rod.
Den Bourne.
