1950 Model 7 rear brake arm
I need the rear brake lever arm, D11M-469. I found a site that has one, but says there is a short and also a long arm. I didn't know there was a short & long arm. Also, says they fit both Model 7 & 88. Any help would be greatly appreciated. Steve
dscf1985-jpg
Hi
I believe the short arm points down for plunger suspension model7s. The long arm is used on the rigids and some early plunger singles.
Norvil stock these (at least, they did last year). If you manage to phone Les (when he is in a good mood), he will tell you which one you need.
