Half my information says flat faced inwards,the other says outwards can't both be right ? 1960 600 99 low pressure system.
Very simple low pressure/s…
Thanks David, So they are…
Thanks David, So they are both right!, and as my spindles are merrily rotating They are right half the time.
Very simple
low pressure/scrolled shaft, the flat faces the ball end of rocker.
high pressure/solid/plain shaft, the flat faces AWAY from the ball end of the rocker.
