Does anyone know how to disconnect the engine management light?
My bike is running well having had the usual problems with the throttle sensor, lambda sensors and oil leak from the primary case sorted with TLC from Teasdale m/c all in the first 700 miles.
.........but now the engine management light has come on again and stayed on!
I would just ignore it but it is irritating to see this light glowing at you in an accusing fashion when the rest of the ride is a delight.
Have you phoned up Teasdal…
Does it not have an OBD2 p…
Does it not have an OBD2 port, it's an EU requirement and you can use it to connect to the EVE and clear the fault.
Have you phoned up Teasdales again Nigel? - they should be able to help - the lambda sensor change that was done by them cured the constant engine management light on my Sept 17 bike
