New Amal Premiers main jets offset
have recently purchased a new set of mk1 prems for 850 mk3 and have found that when it came to changing the main jets you will have to remove float bowl as there is not the clearance for jet removal box spanner as the jets are offset towards back of float bowl on contacting andover norton i was told that they are all offset ,as nobody has commented on this i find it hard to believe,anyone had the same problem?
