Long range fastback question
Hello
Can any owner(s) of a long range fastback measure the length of the seat base from the centre of the seat knurledfixing knob as you look from the side to where the seat meets the petrol tank.
Thanks.......Ady
Mine is a Fair Spares replica from about twenty-five years ago. It hasn't been on for ages but as far as I recall, the fit was OK.
It measures 12" from the middle of the mounting lug to the leading edge, measured just inside the edge lip.
Thanks Richard I'm asking because I fancy putting a fastback tail on my roadster I know I'm going to have to alter the fastback seat by extending the front but that shouldn't be too difficult I see if I can source a secondhand one to cut about
Thanks.....Ady
I could try the fastback seat with a Roadster tank for you (I probably did once actually).
It's a Mk3 though so there is a hinge to unbolt - it won't be tonight.
My original plan was to put the LR kit on for touring with the larger tank but I never arrived at a satisfactory way of mounting the Craven rack and side cases with the FB tail. It all sat too high
Hello Richard
Yes please if its not to much trouble that would be good I know I will be altering the seat in some way if you want to take a picture on a mobile and text it to me my number is 07715076686
Many thanks Richard.......Ady
Many thanks
Previously philip_baker wrote:
I've got a good, solid Fastback steel seat base if you need one.
Yes please Philip please let me know how much and postage unless your anywhere near Cambridgeshire then I come and collect.
Many thanks .....Ady
