Good evening,
Iâm rebuilding my dollshead gearbox ( es2 1939)
I bought all bushes new (non originals) but some have more play than the old ones.
So someone has made them not as good or with the wrong measurements as the originals.
I want to do it good as once and want to buy the bushes I need or make a good copy with the right measurements.
I need following bushes for the axles and the bush in the kickstartshaft.
Main axle
8044(13t) â 8040(18t 1 bush) â 8036(22) â 8034(24t 2 bushes)
Layshaft
8045 (29) â 8041(24) â 8037(20t 1 bush) â 8035(16)
Where can you buy good copies? Are these the same as in the later boxes?
Iâm also searching a kickstartlever(used) with good teeth and a good kickstartaxle.
So if you have one for sale, let me know.
Kind regards
Dirk
Have you tried Norvil? The…
When I rebuilt my Dollshea…
When I rebuilt my Dollshead box I used a lot of Commando bushes. Luckily I had some, and when I compared them, they were the same sizes.
Hi Dirk If you email me at…
Hi Dirk
If you email me at derek.e.ambler@ntlworld.com I can fill you in on all the places to go and what bushes and seals you will need for your dollshead gearbox as I am at present reassembling one after I have been through this excercise. Some of the Commando bushes are not the same, I made this mistake.
regards
Derek Ambler
Have you tried Norvil? They have some later stuff that fits the lay down box, or so their catalogue says!
http://www.norvilmotorcycle.co.uk/gearbox.htm
