Hello all - I've just bought a '63 650 SS with several 'rider mods' already in place (including a 12 volt conversion - no Mag, an as yet unidentified electronic ignition and a RGM belt drive primary ) Apart from this the electrics are unknown to me (I've not delved very deep yet !..) I'm having problems with the headlights dragging the battery flat in about 20 miles or so, then it stops dead and won't start. I don't know how old the battery is (YB5L-B, Lead-acid type) so I want to replace that first anyway with an AGM type.
My questions are - Would it be a good idea to up the battery capacity from 5Ah to 8Ah, or even 9Ah to provide a bit more of a buffer for running the lights?.. Or will this cause problems elsewhere ?.. in which case should I just go with a new 5Ah and see how that goes ?.. There does seem to be room enough in the battery box/carrier for a larger Ah battery..
I've bought the bike as a 'daily rider', it's my first Dominator (had three Commandos previously and still own one..) and it will be ridden at night as well as during daylight hours so at some stage I'll definitely be needing headlights and probably for further than 20 miles !..
Do you not suspect the charging?
Yes/No
Yes fit as many Ahr as you can get in the battery box to any of these bikes. 5Ahr is the Minimum. Initially do not blame the regulator, if there is a quantity issue (as there is here) then the alternator is to be investigated for Amps. (aoservices.co.uk has the answer). Along with battery charge voltage 14.4V (if you are lucky!) In this case the 5Ahr could be down to a couple.
To get to root of this problem please get in touch direct. aoservices.co.uk or Electrical on Tech Team.
Bigger battery needed?
In the Olden Days, when 6 volts was the norm, the old Lucas PUW7E battery was rated at 12Ah. A 5Ah battery (the LVW5E) was only recommended for lightweights. On that basis your battery is seriously underrated. In any case the battery's capacity is only significant if the load is greater than the alternator's output. Assuming that's not less than 60 watts at 2000rpm (I would expect more like 100 watts) then you should not need to drain the battery when running normal lighting.
Changing to an AGM battery won't make much difference if the alternator/rectifier system isn't sending enough charge to the battery. It still needs to be a larger capacity. Another aspect is that you should not discharge a lead-acid battery below about 50%, which means that a 5Ah battery only gives a usable 30W for an hour - if it's receiving no charge. Not 60W as Jonathan Newton says.
Nothing wrong with a bigger battery
Except adding weight. Three possible solutions to prolonged night riding.
1. Have charging enough for consumption. First find out how it's wired. Then find out if rotor and stator is ok. Then check rectifier and regulating. There is different ways how this is done. First thing to check.
2. Keep it at high revs. Low revs gives low alternator output. Might be impractical with modern speed limits and dense traffic.
3. Minimize consumption. If ignition is power hungry, replace with a less hungry or fit a magneto. Fit LED bulbs which consumes less. I'm told that there are now head lamp LED bulbs that gives reasonable light, consuming less. First generation which I tried had a lousy light pattern and was not good at night.
Have a BSA B40 with Boyer Mk4 ignition, a rec/reg from Al, probably a RM21 alternator, standard light bulbs, and a 5 Ah battery. To my surprise works well with lights on at moderate revs. Must have a good alternator!
Thanks for replying Jonathan…
Thanks for replying Jonathan, it's greatly appreciated..
Still trying to identify the Electronic ignition, but I think I have a lead (If you'll pardon the pun..) I think I've discovered who carried out the partial restoration but I can't ring him until tomorrow. I actually had a lot more luck than usual when she died, I'd just pulled onto my drive literally five seconds earlier !.. After I'd charged up the battery she started again easily and ran like a Swiss watch as before, so it's obviously nothing mechanical or a problem with the actual function of the ignition.
One thing that may not be helping is that as part of the restoration/upgrade she also had a rebore with new pistons/rings and due to a now long-term health issue (which unfortunately occurred during the rebuild) the previous owner was no longer able to start the bike. This means that effectively I'm having to run it in from scratch. Obviously this means riding at low speed/revs for a while which won't be putting much charge into the battery even if everything else IS well - which I'm thinking it isn't..
All I do know for certain at this stage is that the alternator was not replaced, so after a new battery that will be my next port of call, maybe an output upgrade there could help ? - As you say the old girl is non-standard (Very in fact !..) so the AO services regulator sounds like a good idea too..
If I do get to speak to the restorer tomorrow I hope to find out exactly what was done and what parts/systems were used to do it, in any case I think I'll have to delve in and have a poke around myself (not easy at the moment, sadly my mother passed away in May so I've had to bring all my bikes/spares/tools etc.. to my place and the garage is now a bit crammed until I can build a new workshop in the Spring..) Thanks again,
John.
Hello Alan, Thanks for the…
Hello Alan, Thanks for the reply..
I've just been having a look at battery dimensions online now to see just how big Ahr I can squeeze in, so your recommendation that this is OK is very reassuring !
When I acquired the bike it had just undergone a large scale programme of 'rider' upgrades and a partial restoration, part of which was a rebore with new pistons and rings. Sadly the previous owner had a serious health issue (with long-term complications) during the restoration which meant he was no longer able to kickstart the bike.. Effectively this means I'm having to run the bike in from scratch with the required low speeds and varied, but relatively low, revs. Obviously this won't be helping the charging problem but it's unavoidable I'm afraid.
The only thing I am certain about regarding the electrics is that the alternator was not replaced, so I too suspect it may be the root cause. Straight after she conked out I recharged the battery and she started easily again and ran as well as before, so the problem clearly isn't mechanical or in the functioning of the ignition. Maybe an upgrade to the output of alternator would help out too ?
I've found out who did the restoration/upgrade and I hope to speak to him tomorrow.. Finding out the make of ignition he installed would be good as well as any other electrical upgrades.. I'll certainly be in touch, many thanks,
John.
Hello Lionel, many thanks…
Hello Lionel, many thanks for your reply..
Just before acquired the bike the previous owner had a partial restoration and a large array of 'rider upgrades' done on the bike (professionally) - The bike is on a 12 volts system but the alternator was not changed after the fitting of the electronic ignition. I've no idea how old it or the battery are, so with all the extra load it's possible that neither are up to the job now ? (especially with headlights on too..)
I'm fitting a new battery anyway and the AGM type is just my personal preference, Alan Osborn has said it is OK to up the Ahr rating so I'll fit the highest I can possibly squeeze in !.. I'll check the alternator output but I'm starting to think it is favourite for being the culprit. I charged up the battery after she died on me and it started and ran as well as before so it's clearly not a mechanical issue or a problem the function of the new electronic ignition.
Also, the bike had a rebore with new pistons and rings as part of the restoration, the previous owner had a serious health issue while this was being done, resulting in him no longer being able to kickstart the bike (hence the sale..) - The upshot of this is that I'm having to run it in from scratch, initially with the required low speed and varied (but relatively low) revs, this won't be helping the charging issue either I suspect.
In the dim and distant past (1992-ish to 2003) I ran a 1970 Mk1 750 Commando Roadster with bog-standard factory electrics as a year-round 'daily-rider' for over 10 years with absolutely no problems so with the more modern electrical systems available today it must be possible to it again ?!.. Thanks again for your reply, it's greatly appreciated..
John.
Hello Mikael - Thanks for…
Hello Mikael - Thanks for the reply and your suggestions
Going by your (and the other) replies I'm starting to suspect the Alternator too.. In fact the only thing I am certain of about the partial restoration and large programme of 'rider upgrades' that the previous owner had done professionally just prior to me acquiring it is that, for some reason, the alternator was not replaced, so add in an electronic ignition, a low Ahr battery and running headlights and it all might be too much for it to keep up with now ?.. I charged the battery after the bike died on me (which with unusual good luck occurred just seconds after I pulled onto my drive !..) and it started easily and ran as well as before, although to be honest I've not ventured out on it since..
I'm replacing the battery anyway with an AGM type with as high an Ahr rating as I can squeeze in so maybe a higher output alternator will help too..
Another problem might be the fact that as part of the partial restoration she had a rebore with new pistons and rings. Sadly the previous owner had a serious health problem occur during the restoration, the repercussions of which meant he could no longer kickstart the bike (hence the sale) - This effectively means that I am having to run the bike in from scratch with the resulting low speed and varied - but relatively low - revs (at least initially..) This is unavoidable of course but it certainly won't be helping the charging issue any..
I had thought of fitting LED bulbs as you suggest, so they could be a help too.. Best wishes and thanks again,
John.
Non original 650ss.
Hi John,
I too have a non standard 650 - I call it a mongrel as it is of unknown parentage.
When I got it around 24-25 years ago (hadn't run since 1970) there were lots of non original bits on it, rubbishy loom, mag that didn't work etc.
I took the decision to build it up as I wanted, not a 'factory museum piece' and I'm glad I did.
As to the electrics, as my alternator rotor wouldn't hold the weight of a small spanner, I went for a new rotor and 3-phase stator with a Japanese (Kawasaki) regulator, along with all new wiring. I have never regretted it. It balances the load of a 60W headlamp and the electronic ignition (whatever model Boyer was current in 1998) at 18-1900rpm. I run a 7Ah battery on the bike and have no issues there.
Al has offered help with checking your alternator output - I would grab that.
Only other thing is to go through all connections in the wiring ( and earths) and make sure they are all clean and good.
Good luck,
George
Hello George, thanks for…
Hello George, thanks for your reply..
My 650SS is definitely similar to yours and I've no intention of returning it to standard. I bought it to be a 'daily rider' and I was at least partially attracted by the 'rider mods' that had already been done, at the moment I just don't know how well they were done ! - I'm sure that when I do get to the bottom of this issue and get it properly sorted it will be a great, reliable bike.. fingers crossed !..
Mechanically it seems great and I'm very pleased with it, it starts easily and runs like a Swiss watch, I've had a total of three Commandos (still have the first one !.) and the 650SS genuinely has the slickest AMC gearbox I've ever used (allegedly rebuilt by RGM) - It's had a full engine rebuild and rebore as well as the full gearbox rebuild, RGM belt primary drive conversion, new wiring loom, the 'as yet unidentified' electronic ignition, a single carb conversion and lots more bits and bobs (but strangely no new Alternator) so it is at least a good platform to start from. I'm hoping to speak with the firm that did the work tomorrow which will hopefully bring some answers and identify the ignition, then I'll get in touch with Alan when I know more about what I'm working with..
Best wishes and thanks again..
John.
Just a thought (Dross Response)
My 650ss bitsa fits much of your description, John.
I always fit an ammeter to my bikes (8Ah Gel Battery in this case) and noticed that I had to hit 50 mph in top before the needle went to the middle (Ammeter) Put the headlight on and discharge all the way. I then thought of my Mk3 Commando and bought an assimulator charge light from Paul Goff. I sine believe that AO sells them too. Anyway, same result. But good to eliminate issues.
The Stator was a new Lucas and so I decided that was not the issue. The Rotor with good magnetism was an old one out of my collection, and guess what? Only by a fraction the air gap was too big. I fitted the correct Rotor and all is charging well.Not all Rotors are the same!
John, you didn't say if you had an ammeter fitted, did you? Or the charge warning system, I have now both on this bike.
PS: The picture is mostly so Robert T can have a better look at my 2 into 1......
The bike behind is my mates 1961 prize winning ES2.
PPS: The bigger the battery the better, to an extent, but I doubt a healthy 5AH is your issue. I use one on my Poor Man's Manx....ES2 motor BTW...
Careful...
With an issue like this do NOT go out buying new alternator or regulator. Find the fault first. You could easily spend £100 or more and still have the same fault. The fault might even be easier, a failed wire in the alternator, if it is an original 6V (RM19) type then the loss of a one set of coils would cause all this. Check DC current after alt/rect and battery charge voltage, then work forward from there. The problem might be with the rotor, but the gap is not that crucial, The quantity of magnetism is. All 6 magnets need to be up to 'scratch'. I can measure magnetism BUT postage can be a 'no no'.Measuring the generated DC as my web site is a short answer. But I will work on a basic magnetism measurer if any one else is interested.
Checking alternator
The simplest way to find if the alternator is charging sufficiently is to check the voltage at the battery. (Lights off) First with the engine off and preferably after standing overnight. This will indicate if the battery is holding a charge. Anything below 12 volts means it isn't. Next check the voltage while running with no load. Preferably at 1000rpm and at 2000rpm. You want 13+ volts minimum. On a car I expect 14+ volts. See what the variation is at different engine speeds. It's more difficult to check the AC of the alternator output on any vehicle, as Al Oz will tell you, so I always check at the battery - DC. I maintain most of my vehicles - a Diesel Motorhome, a petrol Jaguar S-Type and a Skoda Fabia.
My two penn'orth
1) Lamps At the front, Paul Goff's Daylighter headlamp LEDs are the way to go, regardless of whether you are trying to lighten the electrical load (http://www.norbsa02.freeuk.com/goffyWhyNotLEDs.htm). You might want to consider converting the headlamp to H4 (if necessary) in order to use the Daylighter 2 version — they are brilliant (pun intended). His stop/tail LED is also excellent.
2) Instrumentation I endorse the recommendation of Al's battery status monitor (http://www.aoservices.co.uk/data/bsm.htm). I have one as well as an ammeter; the combination provides a useful cross-check.
Please follow what Alon…
Please follow what Alon Osborn says first - he is the club electrical guru! Don’t spend any money until you’ve checked what’s wrong …. easy with a multimeter for a few pounds from the usual outlets!
My name is ALAN
But apart from that a cheap digital meter will NOT measure the charge voltage of your battery. As soon as the engine starts the display will jump about, it picks up the ignition. A specific automotive multimeter might do the job or an analogue 'pointer' meter. You don'y need to know the finite number of volts as you are looking for the charging voltage rise of 2V ish. Checking for a non charging fault (low charge voltage) with a Lucas alternator and Regulator/Rectifier will leave confused as to which is faulty. Replace the reg/rect with original bridge rectifier and if the charge is resumed, then reg/rect is suspect (I can test) running the bike for a short test run or even on the road (with lights on) will be ok. Just don't do a long run without the lights!
For what it's worth I use a…
For what it's worth I use a RM23 single-phase stator with the original rotor, rectification and regulation using a Mosfet Tri spark unit. Voltage at tickover is 14.39V, and stays around this level no matter the revs.
If I use the starter the BSM will indicate green after a minute or so.
Despite the bad press the stators had over the years it seems that they can actually deliver a decent output.
5AH does sound a little light for your machine. But even so, nominally 5Ah at 12 volts gives 60W for an hour. (Check your bulb wattage).
Your problem sounds like you are depleting the voltage level below the threshold of the "unknown" electronic ignition operating range, then she dies. They can be hungry things and certain types quite sensitive to voltage reduction.
Check your charge level and regulation. As its non standard already then I would not hesitate in upgrading to a solid state voltage regulator as sold by AO services.
J
