Hi , Campbell Adie up in Aberdeen I am looking to up the gearing on the Dommie by upping the teeth on the g/b sprocket its meantime is a 19 tooth which is possibly the biggest available ? It seems very low geared as opposed to my Commando ,71 Fastback, its not a fair comparison to make I know but a more relaxed feel on the Dommie would be nice, thoughts ?. Campbell
Changing the box sprocket is…
Engine sprocket to get you there
Are in stock in the spares department 20T and a worn 21 if you're determined. My 88 was a slouch on the hills and I suspected PO had sprocketed it to cut the revs out. Turned out to be a mag issue. That resolved, I then put a 20T in and it pulled it nicely (ONE UP though) and gave a great turn of speed. I liked the flexibility of running in third when in urban limits, but calmed it down on the motorway stretches I can't avoid....
Gearing (Dross reply)
I have yet to take my Dommie racer 88 out on the road but in advance I can tell you that I have fitted a 20 T G / Box sprocket, leaving the engine sprocket as std.
This arrangement works very well on my 99. In fact I also use a 20 T G/Box sprocket on a couple of my singles inc my big bore ES2. (530 cc)
If you do decide to change the gearing, don't forget to re-adjust the rear chain.
PS: RGM have a wide range of G/ Box sprockets, certainly up to 22T.
https://www.rgmnorton.co.uk/buy/amc-gearbox-sprocket-20-teeth-5-8-x-1-4_1068.htm
I'm assuming an AMC box, but might be OK pre 1956
Changing the box sprocket is a lot of work , especially if you dont like it . An extra tooth on the engine is a bit easier as long as you can break the taper. The 88 is a revvy engine so you may find yourself running more in third when in the 30 zone. Even on the 99 i find myself looking for a 5th gear . and changing down to 3rd a lot in traffic.. A 5 speed cluster with a lower 4th gear and an overdrive 5th would make a great improvement .
