Wideline frame number
flattened frame top tube
"flattened frame top tube" -Happy to be corrected, but surely all F/B frames for all singles OHV and OHC have this?
Way back, my M50 certainly needed this.
Frame Number
16511 wouild be too early for a Featherbed Framed bike. Around 1949., which is really pre-Featherbed. Are you sure that the first digit is not a 7? That would fit in with a 1958 Widleine Featherbed.
See attachment.
As you can see from the…
As you can see from the photo the number stamped at the top is fairly indistinct but it looks like a one rather than a seven and pretty much the same the last two 'ones' in the sequence. I am, however, reluctant to scrape off the paint to find out for certain. What I don't understand is how somebody has managed to date it so specifically to February 1958. As for the frame top tube, I don't know enough to say whether this is a feature common to all wideline frames.
Reynolds date stamp?
I have a slimline so it may well be different, but didn't the wideline get a date stamp on the head steady lug like the slimlines did?
See thread https://www.nortonownersclub.org/node/12442 for a discussion on this and where to look. This may answer the question of how the precise date was arrived at.
Note that this a frame manufacturing date, NOT a bike manufacturing date, which was usually a month or two later
Featherbed frame number
Is it possible the top 1 on the gusset is for the model designation? 11 for an International? It’s hard to tell the spacing in photo if there is enough room for three more digits between that top “1” and the last visible 1’s.
Good luck
Pat
I've bitten the bullet and scraped back the paint just to confirm the number, which, as you can see from the attached, shows 16511 with nothing else stamped either above or below. I've also exposed the edge of the gusset next to the headstock which clearly shows a 1, followed by 9 Q. There could be something else stamped above the 1 but I can't make that out.
It seems, therefore, we are no further on but I nevertheless thank you for your comments.
A friend has suggested that the number could be read from the bottom making it 11561. Is that an option?
Frame number
Is there a possibility that the frame number could be 6511X as there should be a horizontal 2 digit number identifying the model just below the top nut and the frame number stamped vertically below the model no.
A 65,000 number would be consistent for a wide line frame.
Here's my frame number for a…
Here's my frame number for a 1959 Dominator 99.
I have another possible…
I have another possible theory, and not a good one I'm afraid, there are bikes knocking about which have been used to 'claim' valuable registration numbers belonging to long-scrapped bikes, I once heard of a 16H which had about 30 different frame numbers on it, mostly not even Norton.
The 1958 registration date must have been with that frame number, would have been taken from a 'logbook' RF60, registration ledger or cardex, and suggests that the age related number was allocated as a replacement, usually if this has happened you can ask what the original number was. The club records officer should be able to tell you what sort of bike 16511 was, if it was a 1949 Manx or 500T, maybe it was not registered until 1958, which is too early for an OHV featherbed, I am no expert on F/B Inters but I know the frames were quite different.
The headstock lug date looks like 1/60 to me, which would be consistent with a Wideline ES2/M50.
Thanks Niall. That is a possibility worth exploring further. What I do know of the history of the bike is that had previously been raced as a large wheel outfit which, in a later incarnation was fitted with a highly modified pushrod motor running on methanol. It was subsequently converted to a road bike but retained the 84mm bore X 100mm stroke giving 525cc and the Model 50 head which gave a higher compression ratio. What I need to find out now is how the seemingly standard wideline frame ended up with that number. I shall make enquiries.
Engine size.
Hi Peter,
Just to let you know, the capacity of the engine works out at 554cc. If you still have the engine and intend to use it, be aware the compression will probably be too high to run on petrol.
What I need to find out now…
You have a V5 with the frame number matching what's stamped on the frame with the tax free status, I would continue to research so you know the bikes background but leave the V5 and frame number as it is. Racers were not interested in keeping bikes as they left the factory but making them faster, parts were changed all the time. It will be like the original 20 year old broom, with 7 replacement handles and 8 replacement heads changed over the years.
Compression
By my rough calcs. Compression ratio would be around 11:1, a 3mm spacer at the base of the barrel would give around 8:1, which is getting nearer to useable with today's fuels.
Dodgy Numbers
Peter......The numbers on the gusset of your frame do not look to me like Factory stampings. The form of the numbers is not quite right for those for a Bracebridge frame.
Dodgy Numbers
Peter I think all the white numbers are shonky. The original numbers 5 and 6 which are black are probably kosha, However the number 16511 is a 1948 number long before featherbeds were made. Don't stir the possum, let the gummint wander on in it's usual lost fashion and take advantage of their ignorance.
frame flattening
On a featherbed International frame, the flattening is at a 45 degree angle, and is around 12" long. This is for clearance on the angled upper bevel cover. What you have on your frame is very different, and looks perhaps suitable for a pushrod single.
If your frame were an International one, the frame number would go like this:
N - 1958
112 - Model 11 is for 500cc International, 2 is Mk2 ie featherbed instead of iron lug frame
76511 - the number of an individual frame, such as yours.
You can expect the N112 to be horizontal, with the frame number vertical below
a 1949 Inter
would be a higher number than that. My father's 1949 500 Inter was 236**
Forecourt fuel will run far…
Forecourt fuel will run far higher compression ratios than 11:1. Modern 125's have far higher CR and a motocross bike builder nearby runs it at 16:1 using rpm that would make you wince. The fuel will work, if you can actually kick the bike over.
Hasn't that also been…
@Bob Matthews
Hasn't that also been repaired where they drilled a hole to fit higher level footpegs? I can faintly see a circle around the 9.
Mine is the same, and even more visible actually..
You're quite right Kevin,…
You're quite right Kevin, you can see the ghost of the welded up hole - even more evident on the inside. Was done before my ownership and the re-stamp of the 9 too.
I have a wideline framed 500cc pushrod single which has, over a number of years been built with parts from many bikes so none of the numbers match. The V5 quotes the frame number as 16511 but thanks to powder coating only the the three 'ones' are still visible stamped vertically on the drive side frame gusset. The V5 states that it was first registered on 13/02/1958 but it now carries a non-transferrable age related registration. I have been told that this was originally built as an International by virtue of the flattened frame top tube on the timing side but any further information would be appreciated.
