Does anyone know where I can get forest green trims for featherbed headlight shrouds?
Mine have split and so far I have failed to find any.
Thank you.
I believe the correct term…
Do you mean the rubbers on…
Do you mean the rubbers on top of the headlight shroud and beneath the yoke? I thought they were all black?
Yes Dan.The ones on my bik…
Yes Dan.The ones on my bike are green but I cannot find any so have ordered the lower rubbers from the club.
i need to find the upper fittings now but no luck so far.
I could indeed Dan but wou…
I could indeed Dan but would prefer not to. I suspect paint would soon peel off due to vibes and movement.
I also think that the current fitments are not original which is maybe why I cannot locate green rubbers.the top ones are made of green trim which looks very similar to the u section trim on the number plate holder. Obviously incorrect but it works.
I believe the correct terminology is fork shroud support bush.
thanks again
