000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Mk2A Commando 1st gear lever travel
Hi All, I've noticed that 1st gear lever travel is quite a bit more than when I select 2nd gear(about 50% more) is there something that can be done to reduce the amount of travel when "going down the 'box"?
I do have a reduced movement in my right foot which I'm hoping will improve, but if I can reduce the travel it should help.
TIA
Paul.
Yes,I thought about that Robert, however, the footrest is in the right place at the mo'.
Do you know where I might get a shorter lever from?( I could cut & shut my one, but will prob' need it for when/if I convert to roadster spec.
I will mention that the bike is a Norvil replica, so head down arse up, long tank,single seat, clip-ons & rearsets & reverse gear lever & camplate, so still 1 up, 3 down.
I've been thinking about going back to roadster spec & I think this is just confirming that my 69yr old legs/ankles ain't what they use to be!
Cheers mate
I had a similar problem on  a  250 Ducati.  could not get  proper riding boots to work  ,I eventually resorted to a rocking pedal  .  Its all made worse  with a bike that has a stretched out riding position .  Time to get sensible  if you want to continue to enjoy  your rides. At 75  its something  I know all about.
Privacy Policy
