000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Rocker spindle
Good morning all.  I've been doing some work on the cylinder heads of my Navigator.  I see that the "inner pillars" that support the rocker spindles have top hat shaped bushes pressed in to place, see photos.
Any ideas on the purpose of these bushes?
Hi John,
Only a guess - but as that end is only splash lubricated, it was decided to have a replaceable bush there in case anything went wrong - better then scrapping the head. In reality, i've never seen any issues there in any engine i pulled apart.
I cannot see the need for lubrication here.
I wonder if "fretting" may have been a problem, the clamping of the spindles isn't that positive.  I have six heads here, all are a reasonable fit on the spindle, so probably not fretting.
Another thought that it was a way of rescuing a manufacturing mistake, the bush is in the parts list, so, again probably not.
Privacy Policy
