can pre war rigid 16H primary cases, reproduced in India, be fitted to a 1936 CS1 inter. Have no end of trouble even finding someone with cases to compare with
Malcolm I have just bought…
Having tried anumber of pr…
Having tried anumber of pre-war cases to fit a 16H buildthereseem to be numerous differences in design, particularly with the inner case, as the extract below from the 1936 parts book would indicate. The CS/CJ cases would seem different from even an ES2, which itself was a one off.
I chose the nearest and fettled the holes and openings on the inner case to fit.
img061-jpg
According to http://www.wd…
According to
http://www.wdnorton.nl/Spare_parts_16H/parts%204.jpg
at least the WD16H outer case is the same as the prewar one.
Malcolm
I have just bought a set of primaty cases from India.
They can not be fitted to anything !
Arne
