Hi All Again
I have fitted the pistons and a friend just passed a comment - Jubilee Piston - Is there a Front & Back and a correct way round, or can they be fitted any how?
There isn't a forward marking on the pistons just a +30 - I fitted both pistons with the +30 being readable from the left hand side. Is this OK?
Thank you in advance
Regards Ian
What does the manual say?
There are no Arrows - both…
There are no Arrows - both valve indentations look the same size - and I can't see anything written in the manual about piston direction when fitting
Ian
No - the pistons can be fitted either way round.
The valve cut-outs are at right-angles to the gudgeon pin & both are the same size
Does the overhaul manual say anything about front or back?
Are there any markings on the top of the piston, or an arrow?
