000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Brass TT carburetter
My 1949 500 Norton inter was exported to Argentina early in January 1949.I believe it is reasonably correct, except that it is fitted with a brass TT carburetter. There are no discernable numbers on flange of this carburetter, indeed it works fine. Would this have been a standard fitting on this year of inter, or was fitted for export?
AMAL carburettor settings and spare parts list 1940 to 1954 states that all inters 1946-54 has T10TT carburettors. So I'd guess yours is correct.
Is a bit unusual. Mine is a brass TT but is marked as a 10TT 34 (year) on the top right of the flange and builders marks on the individual components;Valve block, body and cap.
All the books say that Model 30 Inters from 1945 to 1954 were fitted with a T10TT carby. I have one so marked. It is brass and 2 1/2'' from the needle to the face of the flange, it has a brass float bowl with a bottom feed 14/064 and the mixing chamber locking device is the screw and plunger type. The one I have has a short bell mouth as in the Amal Specs. I hope this helps you. PS The second T in the T10TT is hard to read on mine.
Privacy Policy
