Considering how I built the seized, rusty,water filled Basket case 25+ years ago with very little other than a rebore ,valve grind and new shells, its done very well. It burns no oil,and goes very well (100+) with as much compression as I can manage. I am thinking that I should do "stuff " while I am still able.The oil seeps around the head joint,the motor is not as Quiet as I would like ,(pistons probably) and the big ends/ rods are a bit of a liability now. I'm thinking ,thunder rods and a crank grind or a 650 crank and rods with case mods to suit and a carefull balance job.. Piston skirt coatings to reduce bore/skirt clearance and a multi angle valve seat cut to improve the breathing (the seats themselves are fine). I am interested in what other members think ,and if anyone has had a coating done. I had the seat areas reprofiled on the Atlas and should soon know how that works out. I'm in no rush, still have a 500 Rudge and 860 Bevel vee twin to fix up first.
Hogslayer!
650 crank and rods
hello now my advice is to check what year the crankcases you intend to fit a 650 crank and rods into as all 99 crankcases made before March 1961 will not take a 650 crank without major engineering in the crank and cases and barrels you find the dimensions differ somewhat, just let you know to save you some expenses and time, yours anna j
overhaul the 99
My 99 was rebuilt about the same time as yours as it featured in the 1995 club calendar (August) and then was dry stored I believe for some time. Probably re-commissioned about 5 years years ago. It is standard and is an absolute pleasure to drive around. Acquired by me about 3 years ago. Apart from sorting any obvious issues with yours through past use I wonder why any need to upgrade especially as yours seems to have run so well.and given Anna's comment you may be building in trouble. No criticism intended by the why just curious. I also am not an engineer but learning from the site as I go along so inherently conservative on any changes to original spec.. Whatever you decide good luck. Cheers, Hugh
Normally I would say , If…
Normally I would say , If its not broke,don't fix it. However with the experience I have gained over the years I know I could do a better job now. Probably will wait till I have an alternative bike I can ride at the weekends . And it has served me well for 25+years without lifting the head. And I am now curious why it goes so well!. I will be very carefully measuring the existing valve and ignition timing ,and will be balancing components weights,chamber and port volumes etc to make it as good as it can possibly be. I won't have the years left to do it again so that will be it. One of my boys will get a cracking bike.
...and it's a hobby! Better…
...and it's a hobby! Better than spending evenings vegetating in front of the telly and drinking beer...
Whats wrong with the beer?
Can't wait to get a proper…
Can't wait to get a proper pint of lukewarm hoppy bitter pulled by a proper barmaid. Bottled beer chilled to hide disgusting chemical brew taste is just not the same. And as for cold Lager----YUK!.
You're drinking..
.. the wrong beer. Timothy Taylor Landlord* is available in bottles and is just (well nearly) as good as draught.
*Other beers are available.....
beer
Hello guys this threads are about a model 99 rebuild not beer you been long waiting for And There is nothing wrong with a good rebuilt model 99 motor that has matching numbers to the frame ,to get a good motor all burrs and dings and uneven surfaces in the alloy castings need to be carefully removed and attention played to any cracking in the alloy casings and All oil ways to be cleaned well and attention paied to the cylinder head valve seats and rocker shaft seat resessis for. Out of round or cracking and change the valve guides to bronze valve guides and recut the seats and change all bearings as a matter of course and do try and get hepolite or BHB pistons and rings or Hap Jones pistons these are quality Japanese made pistons made for Norton Twins ,with carefully attention to these motors you can achieve a good long lasting Norton motorcycle engine and when heating any thing please do this in a safe way like using your domestic oven has gas blow lamps can burn you if not used with care and the protective gloves and safety ware and do things in stage's and do not try to do thing all in one go, safety first now have fun ,yours Anna j
With beer at £4+ a pint who…
With beer at £4+ a pint who needs it, or the pub.
Well I have been "T" total…
Well I have been "T" total for 24 years, but often miss the company and liveliness of a traditional English pub, admittedly prices are high, (Government taxes) Duty), e.t.c.
However, unlike the Home drinker, I could never see the point of drinking at home on your own, a bit like having a Birthday party n' not inviting anyone, definitely no surprises round the corner on a night like that!
Maybe, "Ian's" are less sociable than "John's"
Must be the Gaelic slant!
John
Don't forget this ran on standard Norton connecting rods!
Hogslayer, the man who built it John Gregory told (me, not sure who) , that in the early 60s they ran nitro burning bikes with the early 650/Atlas rods that had less meat around the base, the Bracebridge Street jobs, and he never had one of those break either, he said it was just important to have them torqued up to spec, and that the 500/600 torque figures were not used, as he thought this was the problem with the bigger motors, people got the torque figures confused, i.e. tightening up Alas rods to the smaller capacity bikes figures.
Check the bottom-end but maybe do not disturb it, if everything looks and balanced okay. can the sludge trap be overalled without pulling the crank apart? Just do a top-end overall and an overall check, look at the number of Norton's torn apart, rebuilt and giving problems, refurbished the oil-pump clean out the oil-ways fit an external filter, loose some weight and you might see 105 mph!
Best ever "99" was 114 mph @ Mira,(and they never had downdraft inlet port heads I am led to believe,) not down much on a 650 Manxman or SS.
John
