voltage regulator
i have a 16h norton will a voltage regulator / rectifier. do the job of controlling the voltage,or must i buy a far more expensive regulator only unit, any advice will be very helpful thanks pete
The rectifier/regulator is used on alternator models. Your dynamo needs a regulator which has a higher price. Not expensive, compared to the cost and trouble you'll get when the old MCR1electromechanical regulator welds together the contacts killing the dynamo. Don't ask why I know.
