Do you mean...
yes wellseal by stag
hello yes the best sealant you can use on a Norton is Stag wellseal and you can by this in 500ml tins or 80ml tubes please use a artists brush to apply evenly and remove any overruns asp and do keep everything as clean as you can in the process, and Love your Model 19S a great Norton motorcycles Yours Anna J
timing cover gasket'
ian.
use a thin paper gasket with welseal,check the alloy for niks and damage first.
I make my own gasket....
If it’s like my ES2 or M50…
If it’s like my ES2 or M50 they don’t have a gasket, just wellseal. remember there is clearance for the fibre washer to the oil pump, which you want make sure still gives a good seal.
.... between the timing cover and the crankcase? If so the answer is no. I use Wellseal.
