Hello
I would like to ask, does any of you know what this little hole is for .???
thank you
regards Lubos
Sorry, no, but my M50 also…
I think...
there has been a thread on this in the past. But I can't remember the outcome.....
Es2 Little Hole
Hi Lubas
I think it was an extra drain hole from between the bearings, to ease crankcase pressure fitted to earlier models but never needed on later ones. I have blocked mine up on my M50, and fitted a Yamaha reed valve to the breather at the rear of the crankcase, This causes negative pressure in the crankcase, and eliminates any oil leaks even when doing 1000 hard miles a few weeks ago on the 'Picos de Europa'
If this hole is not closed, you may think you have a leak from the join between the chaincase and crankcase, …...........make sure you tap a screw in the hole on the alloy chaincase mounting plate, and fill the hole under the bearing in the crankcase with a seal, and you will have no problems, I sealed the offending hole on my M50 about 3 years ago...........no problems.
Regards John O
Timed Breather ?
If it's the same as the earlier engines, then it's a timed breather controlled by a slot in the housing and a drilling in the mainshaft. It seems a shame to block it...
I would leave it be as the powers intended.......
My understanding is that the hole is there for the intake of cool air into the crankshaft as described in Niels Schoen's wonderful book on SOHC Manxes. Don't mess with Mother Nature.....like Richard said.
ES2
Sorry for my english.... I am from Slovakia and I am 56 and in school the fu****n kommunists taught only russian
anyway:
I have to say SORRY
I looked in to hole again under the magnifying glass and there is no thread ,,,! But there was a screw.... probably put it there last owner. I dont know why.....(that made me mistaken)
I did a little test to show that Michael is right ,! (There we can see that hole is somtimes open and sometimes closed)
I will send a pics
Thank you all for help and helpfulness
regards Lubos
Here's one that I dismantled earlier...
It's an earlier engine too, but the principle appears to be the same. It's difficult to photograph though. Whether air is drawn in or forced out, it seems to meet the requirements for a timed breather to me..You can see the slot machined in the housing for about one third of a rotation which is then open to the drilling in the mainshaft.
Sorry, no, but my M50 also has one!
