Which Adhesive for Tank Knee Pads ?
On 1959 Model 50 which adhesive is recommended for fixing new rubber knee pads to chrome tank side panels ?
Mike Haworth
Nowadays I would try clear silicone glue. Comes in tubes from craft shops. It keeps things in place but can be peeled off if need be. Unlike Evostick which is filthy stuff.
You must roughen up the inside face of the knee pads which ever type of adhesive you use. I used Evostick satisfactorily.
I use double sided golf tape on my slimlines. Model 50's still well stuck since 2000. No luck at all with others, using silicone and even super glue.
