hi everyone has anyone used Venhill Part no:
N01-4-116
With concentric carbs? on a 650ss or atlas
they were not sure which carbs they are for,
Cheers,
Tom
Previously tom_steele wrot…
Tom, you have to be carefu…
Tom, you have to be careful as to where the cable adjuster goes.Some Mk.1 concentric have the adjuster screw on the carb top, some have no adjuster, but use a 'top hat' fitting on the cable entry and the adjuster is in the cable its self. Perhaps this is confusing them.
Cheers lads, Yep twin conc…
Cheers lads, Yep twin concentric premiers all the dealers seem really confused with the 650ss ones
Venhill were not sure which ones of there cables are mono bloc or concentric
Cheers,
Tom
Cheers,
Tom
From 1967 on, 650SS and Atlas where equipped with Concentrics.
I'm pretty sure the cables for the Commandos fit your bike.
Fritz
cheers Fritz appreciate th…
cheers Fritz appreciate that not much info out there for the 650ss cable wise with these carbs
Hi Tom,
As far as I can see on the accessnorton-forum you have a twin concentrics configuration.
So I'd try this one: N01-4-107
Fritz
