Valve timing for Dom 99
Hello friends.
I would have thought that to measure the valve timing on my 1960 Dom 99,all I would need to do is to set the inlet and outlet valve clearances to that specified and, by use ofa dial gauge and timing disc, find the angle at which the valves begin to be depressed.
On myengine timing disc, produced by R.G.M,there isa note on it stating:
On twin cylinder engines valve timing should be measured with 0.016'' clearance using a 0.003'' feeler gauge.
Could anyone explain how this proceedure works?
Thanks for any help. Peter
There is a fairly clear explanation of how cams work (in the context of the much lauded PW3) here: http://www.peterwilliamsracing.com/pw3cam.pdf
There is a thread about the article here: http://www.accessnorton.com/peter-williams-pw3-cam-t7593.html
I think a read of both will illuminate RGM's instruction.
Alan
Sorry, I was too hasty. The second link I gave was not the one I thought it was. I can't for the moment find the intended one. I think it might have been on the BritBike forum. I will have a proper look later.
Alan
Thanks Alan, read the articles on cams,very interesting and informative but not quite what I needed.
What I should like to know is:
after I have opened up the Valve clearances to overcome the problem of the quieting ramp distorting my timing readings, what do I do with the 0.003 feeler gauge? Do I insert it into the valve/rocker gap then rotate the engine so that the gap closes, continue rotating the engine until it is just possible to withdraw the feeler. Is this the point where the timing disc gives the valve opening angle?
could I not just use a dial gauge to determine the point at which the valve starts to move?
Cheers Peter.
I am not sure which way you are turning the engine but if the feeler can be withdrawn, the valve is closing.
I think the reason for the .003 feeler is to allow for inaccuracy of the base circle. I think that with the valve fully closed, the dial indicator is set to zero with the feeler inserted. The feeler is then removed so the indicator will read -0.003. The cam is then timed in the usual way by rotating the engine and graphing the reading of the indicator against the rotation.
Alan
