Tyre problems
I have been suffering with punctures seemingly caused by sharp rubber flash on the inner side of the tyre bead  Avon SM rear  that wears into the tube. Has anyone seen this  on their bikes?. Can you recommend an equivalent  3.50 /19 " as a replacement ? Modern metric tyres dont fit my bike.
queried this issue with Avon? They may reply constructively.
I suppose it does depend on the age of the tyre. Have you tried trimming the sharp stuff off?
I have had this problem 3 times  , current tyre  is new this year,  E mail sent to Avon. I will try to trim off  but  notice a similar detail on a 20 year old NOS  Dunlop TT100 , I also have last years SM which is the same.  Perhaps the Mitchelin Airstop tubes are made thinner or softer now. Off road tube could be a tougher alternative. Do Mitas  have the same detail?.
 Ordered some stronger off road tubes and trimmed off the tire , no response from Avon. Wont buy them again. .
Is it inner tubes? I have to pump up my tyres every time I use them...within a week or two they lose too much air to be rideable.
