Im trying to build a bike from bits but I donât have any mounting bolts (except gearbox upper mounting) does anyone have a list of the bolt sizes and threads so I can procure them?
dan
Check out Molnar for SS ha…
Oops .... Sorry should hav…
Oops .... Sorry should have said, in my defence it was past my bet time! Itâs a 1955 pre featherbed swinging arm frame fitted with amc gearbox. Thanks for themolnar link, they seem to have some, but not the swinging arm spindle. sadly I donât have a parts book yet which doesnât help!
dan
Try checking out this eBay…
Try checking out this eBay link.
https://www.ebay.co.uk/itm/Norton-ES2-Engine-Plate-Studs-Nuts-and-Washers-Stainless-Steel-Rigid/112985750042?hash=item1a4e79ba1a:m:mGv22CtnAeEYN8cVCXz2weg
It is not exactly what you are after but the seller may be able to help.
I notice that the LHS swin…
I notice that the LHS swinging arm mounting in the frame is in fact a slot, having found that I do have a parts book I canât see any special washer or bush, how do you make sure that the arm is central in the frame.
Check out Molnar for SS hardware:
http://www.manx.co.uk/pdf/MPL-Norton_Singles.pdf
