Swinging arm cover plate
More probs! With the bike on the centre stand and the chain (apparently) correctly tensioned I note that it just scrubs across the top of the retaining bolts for the swinging arm spindle cover plate. My question is, do these bolts take a washer under their heads? I can't find them in the parts list. George
Oh dear! This one is obviously not catching the imagination! But i do need a comment or two. I need to know if the bolts holding the plate over the swinging arm bush have washers under them. The bike is a 55 ES2. Cheers, George
Well George, I would be surprised if they did not have washers. Its funny even though its probably 45 years ago that I sold my 54 ES2 I do remember the same fault but that could have been more down to poor maintenance on my part! John
Hi George ...originally the 2 bolts (2x on either side of the pivot ends) were of the "reduced head" type ....(one spanner size smaller) ...they had washers and yes the chain can touch touch the left hand side bolt heads although when off the stand and rider seated, and with the chain correctly adjusted, there should be running clearance.
When it came to replacing the bolts I used the normal sized bolts and washers. I considered that with the larger size bolt heads the chain might touch a fraction more but I would get an earlier warning of a slack chain and more importantly should the heads get abraded, this is better than the chain stradlling the bolt heads and wearing away the actual swinging arm pivot top surface which originally there are signs that this had occurred. So it seems this was a bit of a design error or oversight when Norton, in their urgent quest to have a swinging arm frame on the market simply tacked on the new suspension onto the old plunger frame without correctly doing the geometry calculations to allow for the downward bowing of the top chain run, especially on the over-run.....Les
PS...Just an extra point...if you have overlong shock absorbers fitted this will increase the likely-hood of the chain hitting the bolts...
Thanks guys. I really am most grateful for your comments. I guess the thing to do now (before I replace the primary c/case cover) is take it for a test run and listen.The left hand side is a pig to get to so I'm happy to live with just a slight touch on the over-run. George
Just to tidy this up - test run successful. No bad noise. Changes gear OK. I can find neutral (!!)Primary chain-case refitted; primary oil installed. Now for some good weather........GBTW - it would seem that part of the trick of getting good gear changes is to get the clutch adjustment just right!
