Rocker spindle orientation
Half my information says flat faced inwards,the other says outwards can't both be right ? 1960 600 99 low pressure system.
Very simple
low pressure/scrolled shaft, the flat faces the ball end of rocker.
high pressure/solid/plain shaft, the flat faces AWAY from the ball end of the rocker.
Thanks David, So they are both right!, and as my spindles are merrily rotating They are right half the time.
