Rocker shafts leaking oil
Hello, me rocker shafts seep oil out they are a tap in fit didn't really expect them to leak . the breather is clear just wondering if theres a fix. ive indicated where they leak. if the photo works. Baz
dscf6440-jpg
I have the same leak on my Model 19.
Mike Pemberton said it was because the spindles had been pushed into a cold cylinder head, and that they need removing and reinstalling with Loctite into a warmed up head.
I haven't round to doing it yet.
thanks Peter for the info must admit i used a heat gun on it and didnt cook the rocker cover in the oven. i will have to give the loctite a go.
