Oil leak on 2013 Sport
I have a 2013 Comando Sport. During the running in period to the first service, I had no oil problems. After it was serviced at the dealer (500 miles) I had an small oil leak so I retuned it to the dealer. He replaced the O ring on the bottom of the motor and tested it and everything was fine. When I was driving home I could smell oil smoke so I knew it was leaking again! At one red light smoke was pouring from the engine block. I made it home safely without the engine light coming on.
I lost quite a bit of oil on my garage floor and I had my girlfriend to sit on the bike to keep it centered while I lay on the ground trying to determine the source. The oil continued to drip about 15 minutes after the bike had stopped and it appeared to be coming from where the oil pump is bolted the engine. I was difficult to determine the precise source because the oil was new and clear. I dont have a torque wrench but I checked the allen bolts and they were all "snug."
I will be trailering it back to the dealer after the weekend, but I would appeciate to hear if anyone has had similar problems.
1. The leak only appeared after the 500 mile service
2. The leak only appears after the bike has run for 20 minute or so at highway speed.
3. The leak continues to drip for at least 20 minutes after the bike has stopped and since the engine is now totally covered in oil it is difficult to precisely determine the source.
Hi Donald,
Not had this problem myself but I would guess its leaking from one of the oil pipe banjo's on oil pump as one has to be removed to drain the oil from the cooler when changing the oil. The copper washers may not have been annealed before refitting or the bolt not torqued up correctly.
Hope you get it sorted ok.
Previously colin_roberts wrote:
Hi Donald,
Thanks Colin!
I will mention your sugestion to the dealer when I take it in. I agree is has to be one of the fittings the dealer removed to change the oil!
Hi Donald,
Thanks Colin!
I will mention your sugestion to the dealer when I take it in. I agree has to be one of the fittings the dealer removed to change the oil!
My oil leak problems seem to have been solved.The Norton Tech and the mechanic at the dealer worked on the bike and determined that the oil was leaking out where the starter was bolted on to the motor. Apparently when the motor was assembled, one of the washers/gaskets where the starter motor is attached to the motor got pinched. The problem didn't appear until about 600 miles when the vibration from the motor was enough to open up a small opening between the starter and the main block. They removed the starter and re-installed it and it seems fine!The mechanic took it for a test drive and all was good. I just completed a 1/2 hour test drive at 60-70 mph and I let the bike sit for 1/2 hour and no drips. All seems good now!!!
